- #1
ffrancis
- 11
- 0
Why is fire hotter when fueled by sulfur as compared to say, paper, wood, or charcoal?
Where did one find a statement that indicates burning sulfur produces a hotter fire than paper, wood, or charcoal?Why is fire hotter when fueled by sulfur as compared to say, paper, wood, or charcoal?
chemisttree said:Sulfur is made from hydrogen sulfide in volcanoes. Hydrogen sulfide is made from the thermal decomposition of sulfates (or biological reduction) in contact with low valent metals and water deep within the earth. Hydrogen sulfide gas rises until it reaches the surface and combines with oxygen to produce elemental sulfur. It also happens in some sewer systems. Layers of yellow sulfur are sometimes visible in manholes where air has come into contact with hydrogen sulfide (sewer gas).
Sulfur fuel is often used in fire because it has a low ignition temperature and can easily combust, making it a reliable and efficient source of heat and energy.
Sulfur fuel has a high energy content, which means it releases more heat when burned compared to other fuels. This results in a hotter and more intense fire.
Sulfur fuel can be more dangerous to use in fire compared to other fuels because it releases toxic gases and chemicals when burned. It is important to take proper precautions and use it in a well-ventilated area.
Sulfur fuel can be used in most types of fire, but it may not be as effective in certain situations. For example, it may not be suitable for use in a fire that requires a high level of precision or control.
Sulfur fuel can have negative impacts on the environment. When it is burned, it releases sulfur dioxide, a harmful gas that contributes to air pollution and acid rain. It is important to use sulfur fuel responsibly and find alternative, cleaner sources of energy.
