Number of ways of expressing n as positive integers
  • Thread starter Thread starter dr hannibal
    Integers Positive
The discussion revolves around the function S_n, which represents the number of ways to express a positive integer n as a sum of positive integers, considering the order of summands. The initial values are provided: S_1=1, S_2=2, and S_3=4, with a proposed recurrence relation S_n=S_{n-1}+S_{n-2}-S_1+1. There is confusion regarding the notation and the meaning of expressing integers, with participants clarifying that S_3 equals 4 due to the different combinations of summands. The conversation emphasizes the importance of understanding the last integer in the sum and how it affects the total. Overall, the thread highlights the challenges in grasping the concept and notation related to expressing integers as sums.
dr hannibal
sorry for the many threads
Let S_n denote the number of ways of expressing n as positive integrs..
S_1=1 , s_2=2, s_3=4 ..
Prove that
S_n=S_{n-1}+S_{n-2} ---S_1+1
no idea to prove that :
Mathematics news on Phys.org
Sorry, but to me it's not clear what your question means. What does it mean to express a positive integer as positive integers? I can only think of one way to express 3 as a positive integer, namely by 3. Can you show how S_3 = 4?
Your notation in the equation is also confusing. What is the meaning of three consecutive minus signs?
I assume that you mean S_n is the number of ways to express n as a sum of positive integers, where orders matters.
Consider the different cases for the last integer in the sum, all of which are disjoint, since order matters. There are n different cases.
Explicitly: if the last integer is 1, then the rest of the integers sum to n-1...
it means 3 can be written as 1+1+1 , 2+1, 1+2, 3 so 4 different ways..
Yup that's what I meant
for your hint how would I use notation to represent it ..just one line would be enough
c, its just I have been grappling with this question for far too long and have not made any headway..
Thanks
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
