Geometric Sequence Sum with Non-Traditional First Term?
In summary, the sum of a geometric sequence can be written as "the first term divided by (1 minus the common ratio)". However, this only applies when the series starts with 1 as the first term. If the series starts with a different number, such as 2 or 3, then that number must be included in the sum as well. This was not explicitly mentioned in the book, leading to the question.
kylera
40
In words, the sum of a geometric sequence can be written out to say "the first term divided by (1 minus the common ratio)". Does the first term also apply when the series starts with some other number n other than 1 (like 2 or 3, etc)? In other words, the first term is when n = some other number instead of 1.
Why in the world would you even ask?
[tex]\sum_{n=0}^\infty 1/2^n= 1+ 1/2 + 1/4+ \cdot\cdot\cdot[/tex]
is a geometric series that sums to
[tex]\frac{1}{1- 1/2}= 2[/itex]
Why would you think that
[tex]\sum_{n=1}^\infty 1/2^n= 1/2 + 1/4+ \cdot\cdot\cdot[/tex]
sums to the same thing? It is missing the initial 1 so it sums to 2-1= 1.
Similarly
[tex]\sum_{n=2}^\infty 1/2^n= 2- 1- 1/2= 1/2[/tex]
and
[tex]\sum_{n= 3}^\infty 1/2^n= 2- 1- 1/2- 1/4= 1/4[/tex]
Well, I'm sorry if the question sounded silly and amateurish, but the book I'm using didn't emphasize that aspect.
1. What is a geometric sequence?
A geometric sequence is a sequence of numbers in which each term after the first is found by multiplying the previous term by a constant number called the "common ratio". The first term of a geometric sequence is usually denoted as "a" and the common ratio is denoted as "r". The general form of a geometric sequence is: a, ar, ar^2, ar^3, ...
2. What is the formula for finding the sum of a geometric sequence?
The formula for finding the sum of a geometric sequence is:
Sn = a(1 - r^n) / (1 - r)
Where Sn is the sum of the first n terms, a is the first term, and r is the common ratio. This formula can be used when the value of n (number of terms) is known.
3. Can the sum of a geometric sequence be infinite?
Yes, the sum of a geometric sequence can be infinite if the absolute value of the common ratio (|r|) is greater than 1. In this case, the terms in the sequence will continue to grow and the sum will approach infinity.
4. How can I find the sum of an infinite geometric sequence?
To find the sum of an infinite geometric sequence, you can use the formula:
S = a / (1 - r)
Where S is the sum, a is the first term, and r is the common ratio. This formula only works if |r| is less than 1, otherwise the sum will be infinite.
5. Can the sum of a geometric sequence be negative?
Yes, the sum of a geometric sequence can be negative if the common ratio is a negative number and the number of terms is odd. In this case, the terms in the sequence will alternate between positive and negative, resulting in a negative sum.
