roineust
- 341
- 9
In spite of all the problems that apparently arise from my questions or from what these questions represent (among these problems 'do not seem to agree with the underlying framework'), i would be obliged if someone can answer me the following questions, which i am hesitant to ask here as a thread, since i think the thread will be locked, way before any answer which i can understand will be replied:
Here is a quote which is a part of a reply to a thread that i posted last Thursday, under the subject "Gravitational Waves Question", which states:
"Yes, a passing gravitational wave does, in principle, affect the reading on a weighing scale.."
My initial question is:
Does a passing gravitational wave, in principle, also affect the reading on a weighing scale accelerated in a straight line in space (where there is negligible gravity), as if it was weighing a mass on a planet or for example, weighing on Earth and then in comparison accelerated in space at 9.8 m/s^-2?
1. If the answer to this initial question is in principle YES, the following questions are*:
*But it does not seem to be the answer that i am mostly given and therefore, you can jump ahead to questions 1.B. , 2 and 3.
1.A. Therefore acceleration in a straight line is equal to gravity, to the extent that it is influenced to the exact same amount by gravitational waves, as gravity does, i.e. acceleration of a mass in a straight line produces gravity and can in principle, change and be changed in measurement of properties by gravitational waves?
If the answer to 1.A. is YES or NO, my following question is:
1.B. Does gravity (and acceleration of a mass in a straight line*) also produce gravitational waves? I was answered in previous threads, that gravity and gravitational waves are not the same, because gravitational wave is a tidal wave.
*This question also stands regarding only gravity and not acceleration of mass in a straight line, in case the answer to question 1.A. is NO.
But i don't understand:
1.B.1 If the difference between gravity and gravitational waves (tidal waves), is an essential difference or only a difference in scale of magnitude. If it is an essential difference, can you explain this further or refer to a good explanation, that also relates to how these 2 apparently essentially different phenomenon of gravity and gravitational waves, do influence one another after all?
1.B.2. Why does a mass that moves in a rotational path or in a cyclical path do create gravitational waves, while close to static mass, and mass moving at constant speed in a straight line, and mass accelerated in a straight line, can not produce gravitational waves? Does it have to do with angular acceleration or with other properties of the masses' movement path?
1.B.3. If it has to do with angular acceleration, what is the essential difference that angular acceleration has, in comparison to constant speed and acceleration in a straight line, that produces gravitational waves in one case but does not produce them in the other cases?2. If the answer to the initial question in this thread is NO, the following question is:
2.A. How does this come into terms with the equivalence principle of general relativity, which states that gravity and acceleration are the same?
I seem to be given answers in this relation, which often include the term 'locally' and that the equivalence principle is defined only 'locally'. But i don't seem to understand this well enough: For sure the equivalence principle is not defined in such a way, that it is experimentally not testable?
For example, if the equivalence principle includes by definition of the term 'locally' an area or a point in space, which are infinitely small, i.e. an area or a point in space that size is by definition, impossible to build any experimental equipment that can measure what happens inside such a point or an area? Can you please explain further in this regard?3. What is the difference in scale of magnitude, between the current gravimeters best sensitivity (10^-11 m/s^-2) and the amount of sensitivity needed, in order to be able to influence the reading of the gravimeter by: 1. Gravitational waves measured by current LIGO like devices. 2. Gravitational waves that are perhaps hypothesized to be prevalent through the universe, even if they have properties that are at a scale of magnitude, that is currently not possible to measure by LIGO like devices.
