- 8,917
- 672
This is a C++ class to be used for summation of doubles (floating point). It uses an array of 2048 doubles indexed by exponent to minimize rounding errors by only adding numbers that have the same exponent.
NUM::NUM - array is cleared out when an instance of NUM is created
NUM::clear() - clears out the array
NUM::addnum() - add a number to the array
NUM::getsum() - returns the current sum of the array
link to zip of source file with example test code that adds 1./5. 4,294,967,295 (2^32-1) times and displays a sum using normal addition and using the SUM class.
http://rcgldr.net/misc/sum.zip
This is the key part of the SUM class, the addnum() function:
Code:
void SUM::addnum(double d) // add a number into the array
size_t i;
while(1){
// i = exponent of d
i = ((size_t)((*(unsigned long long *)&d)>>52))&0x7ff;
if(i == 0x7ff){ // max exponent, could be overflow
asum[i] += d;
return;
if(this->asum[i] == 0){ // if empty slot store d
asum[i] = d;
return;
d += asum[i]; // else add slot to d, clear slot
asum[i] = 0.; // and continue until empty slot
