Superposition of two wavefunctions
The discussion focuses on the superposition of two wavefunctions, specifically addressing the arithmetic of complex numbers involved in the calculation. The main equation used is |\psi|^{2}=\psi\psi^{*}, but the user encounters a discrepancy in their results, obtaining a more complex expression than expected. They seek clarification on how their result relates to the simplified form provided in their notes. A reference to complex number properties is shared to assist in understanding the calculations. The conversation emphasizes the importance of correctly applying complex arithmetic in quantum mechanics.
Leb
[SOLVED] Superposition of two wavefunctions
The problem is more of complex number arithmetic more then conceptual :
I simply used the equation given above, but instead of getting 2Re{...} I get :
|\psi_{1}||\psi_{2}| \left( c_{1}c_{2}^{*}\exp({i(\alpha_{1}-\alpha_{2})})+c_{1}^{*}c_{2}\exp({-i(\alpha_{1}-\alpha_{2})})\right)
Could someone explain how is this equal to that given in the notes I attached ?
Leb said:
The problem is more of complex number arithmetic more then conceptual : View attachment 44717
Could someone explaind how is this equal to that given in the notes I attached ?
The following link should be helpful:
http://en.wikipedia.org/wiki/Complex_number#Conjugation
Great, thanks !
Leb said:
Great, thanks !
Glad to help.
