Surface Integrals of first octant
The discussion revolves around evaluating the surface integral ∫∫ F⋅dS for the vector field F = yi + x²j + z²k over the plane defined by 3x + 2y + z = 6 in the first octant. Participants clarify that the parameterization of the plane should be r(x,y) = xi + yj + (6 - 3x - 2y)k, correcting earlier misconceptions about the domain and the nature of the problem. The importance of sketching the plane and identifying the correct domain for integration is emphasized, as well as ensuring the normal vector is accounted for in the integral calculation. Ultimately, the conversation highlights the need for proper parameterization and understanding of the surface integral's formulation.
galaxy_twirl
Evaluate ∫∫ F⋅dS, where F = yi+x2j+z2k and S is the portion of the plane 3x+2y+z = 6
The orientation of S is given by the upward normal vector.
∫∫S F⋅dS = ∫∫D F(r(u,v))⋅||ru x rv|| dA, dA=dudv
[/B]
Since this is the first octant, our domain will be 0 ≤ u ≤ π/2 and 0 ≤ v ≤ π/2.
I have to obtain the equation of the form r(u,v) before I proceed to substitute it into the equation given by F. However, I am stuck trying to obtain the equation r(u,v).
Just wondering, is r(u,v) here the vector equation of the plane? (Cos r(u,v) is usually in the form i, j, k). From deduction, I found that x=y=z=1.
Thank you for any help given. :)
[/B]
No it won't. This problem has nothing to do with circles or ##\pi##. It is a plane slanted up against the first octant coordinate planes and its xy domain is not a rectangle. Have you drawn a sketch?
Let ##u=x,~v=y## be your parameters. So then ##\vec r(x,y) =~?##
Oh nope, I haven't drawn a sketch. I think I misread the question. How do I sketch the intersection? I know how to sketch the octant, which is like a quarter of a 3D sphere, but I am unsure of how to draw the plane. May I have your advice on sketching the plane? :)
r(x,y) = 3u i + 2v j + k = 6, am I right to say this?
Thanks! :)
Nothing in this problem is "like a 3D sphere". Find the x,y, and z intercepts. Join them with straight lines in the coordinate planes, and that will show you the first octant portion of the plane.
Thanks! :)
No. Not even close. You have x and y on the left and u and v on the right. Like I said before, your parameters are x and y. Your parameterization should look like ##r(x,y) = xi + yj + ? k##
LCKurtz said:
No. Not even close. You have x and y on the left and u and v on the right. Like I said before, your parameters are x and y. Your parameterization should look like r(x,y)=xi+yj+?k
Oh oops. I think it should be r(x,y) = 3i + 2j + k - 6, right?
Hmm I shall try again. :)
Does it look right?
LCKurtz said:
Does it look right?
I tried to do this as I learned how to convert cartesian equation of a plane into its vector parametric form at A levels:
May I know if what I had done is correct?
Assuming it is correct, I guess my parametization of the plane should be:r(x,y) = xi + yj + (6-3x-2y)k
right? :)
right? :)
Yes, that is correct. Have you figured out the xy domain?
right? :)
Your parametrization looks fine. So ##\vec r(x,y) = x \hat i + y \hat j + z \hat k## where ##z = 6 - 3x - 2y##.
Looking at the theorem you provided in the given equations:
You should notice you are using the wrong equation. In-fact, your normal vector has completely disappeared unless you intended to mean:
$$\iint_S \vec F(x, y, z) \cdot d \vec S = \iint_S \vec F(x, y, z) \cdot \vec n \space dS = \iint_D [\vec F(\vec r(x,y)) \cdot \vec n] \space ||\vec r_x \times \vec r_y|| \space dA$$
It can be shown with ##\vec n = \frac{\vec r_x \times \vec r_y}{||\vec r_x \times \vec r_y||}## that the surface integral can be evaluated in the following fasion:
$$\iint_S \vec F(x, y, z) \cdot d \vec S = \iint_D \vec F(\vec r(x,y)) \cdot (\vec r_x \times \vec r_y) \space dA$$
which is much simpler in many cases.
  • · Replies 21 ·
