Surface of a cone by integration
The discussion revolves around the calculation of the surface area of a cone using integration techniques, specifically contrasting the methods for calculating volume and surface area. Participants explore the implications of using infinitesimal disks versus infinitesimal conical frustums and the mathematical reasoning behind these choices.
  • Some participants suggest that while volume can be calculated using infinitesimal disks, surface area requires considering the slant of the cone, necessitating the use of infinitesimal conical frustums.
  • There is a discussion about the correct formula for the lateral surface area of an infinitesimal conical frustum, with some arguing that it should include a term for the slant height.
  • One participant presents inequalities for volume and surface area, indicating that higher-order terms can be neglected in volume calculations but not necessarily in surface area calculations.
  • Concerns are raised about the treatment of infinitesimals and the validity of estimates when calculating surface area, with some participants questioning the neglect of higher-order terms.
  • Another participant emphasizes the difference between first-order and second-order infinitesimals in the context of the calculations.
Participants express differing views on the appropriate methods for calculating surface area and the treatment of infinitesimals. There is no consensus on the correct approach, and the discussion remains unresolved regarding the validity of certain mathematical steps and assumptions.
Participants highlight the importance of ensuring that estimates are valid to the first order in infinitesimals and discuss the implications of neglecting higher-order terms. There are references to specific mathematical expressions and inequalities that illustrate these points, but the discussion does not resolve the underlying uncertainties.
themagiciant95
If i want to calculate the volume of a cone i can integrate infinitesimal disks on the height h of the cone.
I was told that if i want to calculate the surface of the cone, this approximation is not correct and i have to take the slanting into account, this means that instead of infinitesimal disk i have to consider infinitesimal conical frustum and integrate the lateral surface of each infinitesimal conical frustum. Why for the surface i can't use infinitesimal disks as for the volume calculation ?
Furthermore, the formula for the lateral surface of a conical frustum is :
Now, let's consider an infinitesimal conical frustum.
For h\rightarrow 0 , R_{1}\approx R_{2} so (R_{1} - R_{2})^{2} \rightarrow 0 and the surface of an infinitesimal conical frustum would be2\pi R_{2}\,dh, however i was told that it's not correct. The correct one is 2\pi R_{2}\sqrt{ d(R_{2}-R_{1})^{2}+ dh^2}, why?
As for surfaces of full cone
The bottom circle pf radius r:
A_b=\pi r^2
The side partial circle for cone height h, so with central angle ##\phi##
A_s=\pi (r^2+h^2) \frac{\phi}{2\pi}
the bottom circle and the side partial circle share the periphery
2\pi r = \phi \sqrt{r^2+h^2}
\phi=\frac{2\pi r}{\sqrt{r^2+h^2}}
So
A_s=\pi r \sqrt{r^2+h^2}
From this fulll cone case you can deduce the answer for your case of cut parts.
themagiciant95 said:
For h→0h\rightarrow 0 , R1≈R2R_{1}\approx R_{2} so (R1−R2)2→0(R_{1} - R_{2})^{2} \rightarrow 0 and the surface of an infinitesimal conical frustum would be2πR2dh2\pi R_{2}\,dh, however i was told that it's not correct. The correct one is 2πR2√d(R2−R1)2+dh22\pi R_{2}\sqrt{ d(R_{2}-R_{1})^{2}+ dh^2}, why?
The square of infinitesimal appears in square root. So it should be treated not second but first degree infinitesimal in the formula.
It's an interesting question of how you know when these estimates are correct. Let's look at the two cases of the volume and the area. If we look at the volume, we can see that:
$$\pi R_1^2 h < V < \pi R_2^2 h$$
If we now imagine an infinitesimal frustrum of height ##dh##, we see that:
$$\pi r^2 dh < dV < \pi (r + dr)^2 dh = \pi (r^2 +2rdr + dr^2)dh$$
And, as we can neglect higher order terms, this gives us a valid equation for the infinitesimal volume element:
$$dV = \pi r^2 dh$$
When we look at the area, however, we see that:
$$2\pi R_2 s < A < 2\pi R_1 s$$
And, for an infinitesimal frustrum:
$$2\pi r s < A < 2\pi (r+dr)s$$
And, we can see that:
$$s = \frac l h dh$$
Where ##l## is the slant height of the full cone.
This gives us the equation for the infinitesimal surface area element:
$$dA = 2\pi r \frac l h dh = \frac{2\pi l}{R}rdr$$
The moral is that you really have to ensure that your estimates are valid to the first order in the infinitesimals.
d(R_2-R_1)^2=[d(R_2-R_1)]^2 =(dR_2-dR_1)^2 \neq d[(R_2-R_1)^2]=2(R_2-R_1)(dR_2-dR_1)
might be of your help. RHS is first order and LHS is second order infinitesimals.
You do not have to refer the estimation
(R_2-R_1)^2 \rightarrow 0
anywhere.
anywhere.
For the frustrum, you can do:
$$dA = 2\pi r dl$$
And, with ##L## as the slant length of the fulcrum, we have:
$$dl = \frac{L}{R_2 - R_1}dr$$
This gives:
$$A = \int_{R_1}^{R_2} \frac{2\pi L}{R_2 - R_1} r dr = \frac{\pi L}{R_2 - R_1}(R_2^2 - R_1^2) = \pi L (R_1 + R_2)$$
And, in terms of ##h##:
$$A = \pi (R_1 + R_2)L = \pi(R_1 + R_2)\sqrt{(R_2-R_1)^2 + h^2}$$
Finally, this makes sense as:
$$A = 2 \pi R_{avg} L$$
$$dV = \pi r^2 dh$$
Why can we neglect those higher-order terms ? Furthemore, if we do this than \pi r^2 dh &lt; dV &lt; \pi (r + dr)^2 dh = \pi (r^2 +2rdr + dr^2)dh becomes pointless
ps: i think i have not understood why you have underlined this chain of disequalities
Neglecting higher order terms is precisely what I've done. In your OP you also neglected terms that were of first order - in your infinitesimal equation for the area element.
Yes but i don't understand the rules when dealing with infinitesimal quantities. It's the only thing i can't deeply understand in undergraduate physics and i haven't found a book about it.
ps: i think i have not understood why you have took care of this chain of disequalities: \pi r^2 dh &lt; dV &lt; \pi (r + dr)^2 dh = \pi (r^2 +2rdr + dr^2)dh . For what purpose ?
Yes but i don't understand the rules when dealing with infinitesimal quantities. It's the only thing i can't deeply understand in ungraduate physics and i haven't found a book about it.
That was to check that the equation ##dV = \pi r^2 dh## is valid to first order.
Whereas, you have:
the surface of an infinitesimal conical frustum would be 2\pi R_{2}\,dh,
But, the width of the area element is ##ds##, which is not equal to ##dh## to first order. Instead, we have:
$$ds = \frac L R dr$$
Where ##L## and ##R## are the slant height and maximum radius of the full cone.
9K
9K
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 31 ·
