Surface Tension(fluid mechanics)
4 replies · 5K views · last reply
Godwin Kessy
May anyone help me out on this model!
On surface tension the model used is that it acts as a skin on top of liquids, So when a body floats on top of liquid due to surface tension does it stay on top of the fluid molecules or between the surface molecules! And how does the molecules prevent the body from sinking!
Hi Godwin! :wink:
From http://en.wikipedia.org/wiki/Surface_tension#Cause" …
At the surface of the liquid, the molecules are pulled inwards by other molecules deeper inside the liquid and are not attracted as intensely by the molecules in the neighbouring medium (be it vacuum, air or another liquid). Therefore, all of the molecules at the surface are subject to an inward force of molecular attraction which is balanced only by the liquid's resistance to compression …
So the body stays outside the liquid, and it's for roughly the same reason that it would stay outside a solid … liquids and solids both "stay together"! :smile:
The surface is pulled down slightly at the edges of the suspended object.
This gives an upward component to the surface tension at the object.
Thank you! I got you well!
There comes else, May you help me out on the derivation of excess pressure
How comes pressure due to surface tension is simply
Pressure T = 2(pie)rT/A
Where 2(pie)r=Circumference
T=Surface Tension
A=Surface Area of bubble
While the surface Tension force considered in per length and not on the whole surface Area as Pressure is concerned!
This is an unfortunate model to use- an effect of demanding that everything reduce to some sort of atomic model.
First, objects do not 'float' due to surface tension- they float (or sink) due to bouyancy- i.e. gravity.
Surface tension affects *wetting*. Insects that can stay on top of a water surface do so because they do not get wet- the interfacial energy creates an energy barrier, preventing their skin (or whatever passes for insect skin) from getting wet. If the water had a thin film of oil, which decreases that wetting barrier, the insects would most likely fall right in.
The Laplace formula for the pressure jump at a curved interface is simply due to this energy barrier- the energy cost associated with creating a surface. The idea that surfaces have an energy independent of the bulk material is due to Gibbs. So, interfacial tension has units of energy/area. Note there is also line tension, which occurs at a three-phase line (e.g. water-air-solid).
