Surface Tension Help i Cant Understand
Interfacial tension is generally lower than surface tension due to stronger adhesive forces between two liquid phases compared to those between a liquid and a gas. Surface tension specifically refers to the interface between a liquid and a vacuum, making it a distinct concept. Interfacial energy can vary, indicating different wetting behaviors, including low (wetting), high (partial wetting), and even negative values (diffusion). Understanding these differences is crucial for applications in fluid dynamics and material science. Clarifying these concepts can enhance comprehension of fluid interactions.
bestfmuzik
Clarification on surface and interfacial tension?
Interfacial tensions are less than surface tensions...
The reason given in book is :-
because the adhesive forces between two liquid phases forming an interface are greater than when a liquid and a gas phase exist together.
I don't understand this ...Why interfacial tension is low ...?
'Interfacial energy' is often used interchangeably with 'surface tension'. Strictly speaking, 'surface tension' refers to the interface between a substance and vacuum- in this sense, it's a limit.
Interfacial energy can be low (wetting), high (partial wetting or nonwetting), and even negative (diffusion).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
