Comparing Large & Small Bodies Using Gravity & Surface Tension
Differentiating large and small bodies in physics involves understanding the influence of gravity and surface tension, which can vary significantly based on scale. The Bond number is a relevant concept for comparing these scales, as it helps determine the dominance of gravitational versus surface tension forces. However, defining "large" and "small" is not straightforward and often depends on context, as there are no strict size thresholds. Classical physics typically applies to most scales, but quantum mechanics and relativity come into play at atomic scales and near-light speeds, respectively. Ultimately, the classification of bodies as large or small is subjective and reliant on the specific reference frame used.
nard
Can somebody tell me how to differentiate a large scale to a small scale? I want to know what he/she is based on. What if you had to compare the scale of large and small bodies using gravity and surface tension, what would be your first move?
The Bond number? I don't really understand your question.
I didn't refer to the bond number in my post. Suppose u have the surface tension of water maybe at normal temperature, and u are to use it to find a scale that separates large to small bodies, for you to do that u first have to know what a large scale and a small scale body is and then proceed.
I don't think physics is as simple as "smaller than 5 meters you use these equations, and bigger then 5 meters, you use these other equations". The equations typically require you to know the actual volume or radius or mass of the object. With that said, near atomic scales, quantum theory is used, and near the speed of light, Einstein's relativity is used, otherwise classical physics usually does just fine.
When i saw this question i realized that if someone asked me what a large and small body is, i wouldn't have a specific answer. I just think that large and small depend on a reference you have given yourself.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
