Symmetry in Landen's transformation in elliptic integrals
sshzp4
http://en.wikipedia.org/wiki/Landen%27s_transformation"
Since both the expressions a_1 and b_1 in Landen's transformation are selected in an arbitrary manner, is it all right to define a_1 with the geometric mean and b_1 with the arithmetic mean, instead of as given in the above link? I think so, but what is your opinion?
Irrelevant background: In the 1975 Journal of Colloid and Interface Science paper by the Russians Derjaguin, Muller and Toporov, the authors attempt to take long range van der Waals type adhesion into account during contact deformation. They use the Landau Lifgarbagez formulation (Vol 7, Theory of elasticity) for the deformation profile of two symmetric solids, under loading and uniform contact, for describing the deformed surface profile. They end up with an elliptic integral (Eq. 6, in the paper) which they magically transform to the regular complete elliptic int. of the first kind form. I am trying to re-derive their solution and it appears that the symmetry argument is important to keep the value of the elliptic modulus under 1. Otherwise, they should end up with a diverging series solution to the integral.
That looks true to me. Using the first transformation in the citation:
\begin{aligned} \int_0^{\pi/2}\frac{dt}{\sqrt{a^2\cos^2(t)+b^2\sin^2(t)}}&amp;=\int_0^{\infty}\frac{dx}{\sqrt{(x^2+a^2)(x^2+b^2)}}\\<br /> &amp;=\int_0^{\infty}\frac{dt}{\sqrt{(t^2+\left(\frac{a+b}{2}\right)^2)(t^2+(\sqrt{ab})^2)}}\\<br /> &amp;=\int_0^{\infty}\frac{dt}{\sqrt{(t^2+(\sqrt{ab})^2)(t^2+\left(\frac{a+b}{2}\right)^2)}}\\<br /> &amp;=\int_0^{\infty}\frac{dx}{\sqrt{(x^2+A^2)(x^2+B^2)}};\quad A=\sqrt{ab}, B=\frac{a+b}{2}\\<br /> &amp;=\int_0^{\pi/2}\frac{dt}{\sqrt{A^2\cos^2(t)+B^2\sin^2(t)}}<br /> \end{aligned}<br />
Thanks Jack. That's how I chose to consider it as well. And it certainly is true when a, b and A, B are defined over the real domain. But if we examine the definition over a complex field, the transformation seems to stretch things a bit. But nevertheless, elliptics are usually defined exclusively over the in the real space and that fits my case. Thanks!
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
