Symmetry of motion in the special theory of relativity
  • Context: Undergrad
  • Thread starter Thread starter qnt200
    Motion
The discussion revolves around the principle of symmetry of motion in the special theory of relativity and its correspondence to the real physical state. Participants explore the implications of this principle, questioning its foundational status and the nature of motion as perceived by different observers. The scope includes philosophical considerations, experimental evidence, and historical context related to relativity.
  • Philosophical exploration
  • Some participants argue that observers in relative motion cannot definitively determine which is "at rest," leading to the conclusion that both can only guess about the true nature of motion.
  • Others propose that the lack of experimental tests to distinguish between observers implies that the concept of "really at rest" does not correspond to anything physical.
  • One participant asserts that the principle of symmetry of motion is accepted because it successfully explains a wide variety of experimental results, suggesting it does correspond to the physical state.
  • Another viewpoint emphasizes that the principle of symmetry is a powerful feature of physics, rather than a problem, and challenges preconceived notions of 'realness' that do not align with observations.
  • Some participants highlight that knowledge of past movements is unnecessary for determining current motion; an accelerometer suffices to indicate whether one is at rest or accelerating.
  • There is a historical reference to Galileo's principle of relativity, which was extended by Einstein to encompass electromagnetism and all laws of physics.
  • A participant questions what discoveries might have been missed if the principle of symmetry had not been accepted, indicating a speculative aspect of the discussion.
Participants express multiple competing views regarding the foundational status of the principle of symmetry of motion and its correspondence to physical reality. There is no consensus on whether it fully corresponds to the actual physical state, as some assert it does while others challenge its validity.
Some arguments rely on historical context and experimental evidence, while others highlight philosophical implications. The discussion reflects a range of interpretations and assumptions about the nature of motion and the role of observers in relativity.
qnt200
TL;DR
Does the symmetry of motion in the special theory of relativity correspond to the real physical state?
I assume that the principle of symmetry of motion leads to the following consequences:
Observers in relative motion cannot definitively determine which one is "at rest" and which is "in motion." Each observer can consider their own frame as stationary and the other as moving. In other words, neither observer has sufficient information to definitively describe the true nature of the motion. Therefore, it can be said that both observers can only guess—rather than truly know—what is happening in reality.
This leads to the following problem:
It is evident that observers lack sufficient information about their past movements. This lack of information is the reason they arrive at contradictory conclusions.
Therefore, it seems to me that the principle of symmetry of motion does not fully correspond to the actual physical state of objects. Moreover, it is clear that drawing reliable conclusions is impossible without adequate information about the motion's history.
I do not understand what led to the principle of symmetry of motion—apparently lacking a solid physical basis—being accepted as a foundational concept in the special theory of relativity.
There is a philosophical leap that one should make. It is, perhaps, a variant of Occam's razor.
If there is no experimental test that can distinguish between two possibilities then the distinction does not even exist. It is not that we cannot tell which observer is really at rest. It is that the concept of "really at rest" does not correspond to anything physical.
That at least is clear. It is accepted as a foundational concept because it successfully explains the result of a wide variety of experiments.
https://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html
The evidence supporting it is overwhelming. It does correspond to the physical state, and is an exceptionally solid physical basis.
qnt200 said:
TL;DR Summary: Does the symmetry of motion in the special theory of relativity correspond to the real physical state?
Einstein deals with that point in the introduction to the 1905 paper. It was partly the unsuccessful attempts to detect an ether and the lack of any sense of absolute motion in the phenomena of electromagnetism.
If you search online, you'll find the paper.
The theory says that only "inertial" motions are relative (or symmetric), whereas accelerated motions - as indicated by comoving accelerometers - are "absolute".
They don't need anything to know about their past movements, they only need an accelerometer - an indication of zero means they can consider themselves as being at rest in their respective inertial frames; indicating more than zero means they are accelerating and constantly changing there (momentary) inertial rest frames.
Experiments couldn't detect any "absolute" inertial motion with respect to a frame in absolute rest ("aether"), so the most easy explanation is that no such motion exists (examples are the Michelson-Morley experiment, Hughes-Drever experiment etc.).
This principle is not specific to SR, but much older:
https://en.m.wikipedia.org/wiki/Galilean_invariance
It's even better: Each of them can choose from an infinite number of equivalent reference frames to do physics using the same laws.
It's not problem for physics, but rather a great powerful feature. It's a problem for armchair philosophers with preconceived notions of 'realness' which don't match observations.
The idea of the "principle of relativity" began with Galileo and mechanical experiments
https://en.wikipedia.org/wiki/Galileo's_ship#1632_thought_experiment
which was extended by Einstein to include electromagnetism and all the laws of physics.
The geometric analogue is... on a Euclidean plane, given a circle and two radial directions, which direction is "the horizontal direction"?
Your argument is strong, but it is also familiar to me. However, I am looking for a concrete and clear explanation because I am interested in research in this area. Perhaps you could suggest a work that critically addresses this topic.
In principle, we can also ask what else might have been discovered if this principle had not been accepted. We do not know the answer to this (similar to observers in the principle of symmetry of motion).
In that case, observers can only determine whether they are in the phase of acceleration or uniform motion.
They are unable to assert that one is at rest while the other is moving, or vice versa, nor can they make any other conclusions about motion beyond whether it is uniform or not. The reason is that they lack information about past motion (acceleration).
In other words, their knowledge is insufficient to provide a true physical assessment of the motion of objects. This aligns with the principle of symmetry of motion, but this symmetry does not provide a realistic physical picture, as it is possible that the objects are moving at speeds unknown to the observers.
Correct, because neither is "at rest" in any absolute sense and each of them is at rest in his own frame of reference and in motion in the others frame of reference.
You are truly wasting your time arguing against Special Relativity. It is reality and has been shown to be such via thousands of experiments. **
** that's probably a gross underestimate.
yes, but it does not follow from this that….
This conclusion requires an additional assumption: that there is such a thing as absolute motion that is a necessary part of a “true physical assessment” of the motion of objects. So far you have not justified that assumption.
Yes.
No - both are free to assert that either or neither is at rest.
No. The reason is that there is no measureable difference between the state "I am at rest" and "you are at rest". So who is at rest is nothing more than a matter of convention.
It's very nice that when I am on a commercial airplane I can consider the airplane to be stationary. When I need to walk to the bathroom I do not need to consider the 400mph of the airplane before I take a step. ;-)
Reminder:
"able-to-be-at-rest" is not equivalent to "being inertial".
The link I gave you and all the references therein.
What explanation can possibly be more concrete than actual experiments?
Sure. That has been studied. Robertson’s famous paper (see the specific citation in the link above) showed how the experimental evidence is sufficient to deduce the math of relativity even without the postulates.
So we would have gotten to the theory of relativity simply from the evidence. The fact that the postulates (in advance) predicted such a large body of evidence is a masterstroke of theory. But at this point, with the existing evidence, we would be here regardless.
Numerous real physical experiments disagree with you. When your opinion about what constitutes a realistic physical picture disagrees with real physical experiments, then it is time to revise your opinion
If a theory is wrong it generally gets disproved. Principles and postulates never stopped the experiments.
Physics is constantly being experimentally tested. It's a common misconception that physicists generally get credit for confirming established theories. It's quite the reverse. The way to make a name for yourself is to do an experiment with a surprising result. Or, at least, a result no one has seen before.
Thank you for your constructive criticism and helpful answers. Unfortunately, I feel that I have not fully received an explanation that provides the real logical reason for accepting the symmetry of motion in the special theory of relativity.
Perhaps this simple example will better illustrate the point I am trying to make:
Initially, two observers are at rest in inertial reference frames. Then, one of the observers briefly accelerates, reaching a relative velocity v with respect to the observer who did not accelerate. After the acceleration phase, both observers are again in inertial reference frames.
Now, considering the velocity relationship between the two observers, the following can be said:
1. If the observers know the history of acceleration, they can conclude that the velocity of the observer who experienced acceleration is greater than that of the observer who did not accelerate. This conclusion reflects the actual physical situation.
2. If the observers do not know the acceleration history (the case of motion symmetry), they cannot draw meaningful physical conclusions about the relationship between their velocities. This lack of information implies that the symmetry of motion lacks physical significance, as observers do not have enough data to provide a relevant answer.
NO, it most emphatically does NOT. You KEEP forgetting that all motion is relative, so there are objects for which one is seen as moving faster and objects for which the other is moving faster. This is VERY simple relativity and was known long before Einstein.
There IS ONLY ONE meaningful relationship between the two after acceleration and that is that each sees the other as moving and they see the same relative velocity.
None of this has anything to do with special relativity!
Plus the minor fact that it is all wrong :smile:
No. They could have initially regarded themselves as in motion and one braked to a stop. There is no measurement you can make that will tell you whether your description or mine is right or wrong. That is the reason for accepting the principle of relativity. It says there is no experiment that can tell the difference and that prediction has been true in every case we've ever tested.
This conclusion does not reflect the actual physical situation. It just reflects your personal opinion. An opinion which is not confirmed by actual physical evidence.
You have failed to recognize this point that has been made multiple times now. What you repeatedly call “the actual physical situation” is not actually physical. A mountain of experimental evidence shows it.
I don't think that logic fits. Relative to what could the observers claim they were moving? In the context of the symmetry of motion, there are only two observers in space. Initially, they were at rest relative to each other, with no external reference point to orient themselves.
It is clear that your idea introduces an additional element—a point of orientation—which is absent when considering the symmetry of motion. This additional element changes the nature of the problem, as it implies a reference frame external to the observers, which is not part of the original scenario.
The final state of the one who changed speed.
Also, remember that the principle of relativity is a postulate. There is no purely logical reason for accepting it - you simply assume it is true and deduce the consequences if it is so. In this case the consequences are either Newtonian physics or special relativity. We then propose that the speed of light is invariant and therefore reject Newtonian physics.
All we have done so far (edit: or more precisely, all we would have done so far if we'd actually deduced anything rather than merely stating the results of the deduction) is show that the postulates do not lead to self-contradiction. We would have to reject one or other or both if they did, but they do not. We then compare the predictions of special relativity to experiment, and find that it is accurate in all cases we have tested. That is the justification for accepting the postulates of relativity.
In order to challenge the postulates you would have to build a theory that does not rely on them and show that it makes the same predictions as relativity to our current available precision, and then propose an experiment that could differentiate between them. Coming up with new ideas for theories is fairly easy, but the rest of it is hard. Most ideas are instantly falsified because they make incorrect predictions for experiments that have already been done.
Ok. But--
Yes, at rest relative to each other. Not in any absolute sense.
No, it doesn't. You are the one who is introducing an additional element, by giving a privileged status to the frame in which both observers are initially at rest.
No, it doesn't. The second "reference frame" is relative to the observer who, in your scenario, accelerates for a period of time, after they have finished accelerating. It is not external to the observers.
Your additional element changes the nature of the problem, by making an assumption that is not necessary. You have constructed your scenario so that it seems to you like there is no such assumption--by your construction, only one observer experiences proper acceleration, so that is the one that is "moving" after having done so.
But suppose we now have the other observer, who did not experience any proper acceleration initially, do so--just enough so that both observers are at rest relative to each other again. We now have the same condition as the initial condition of your scenario: two observers, at rest relative to each other, nothing else. So by your logic, both observers are now at rest. But that contradicts your claim that experiencing proper acceleration put one observer "in motion", because that observer did not accelerate any more--they stayed inertial while the other observer accelerated. So they did nothing to change their state from "moving" to "at rest". Yet it somehow changed, because of something the other observer did.
When you carefully unpack all of this, you arrive at the principle of relativity: there is no consistent way to assign the states "moving" or "at rest" in any absolute sense. You can only do it relative to some particular object or reference frame--where here "reference frame" means a physical construction that is set up so that all its parts are at rest relative to each other.
It does fit. They were initially moving relative to any inertial frame which is moving with respect to their initial rest frame. There doesn’t need to be any object at rest in a frame for you to use it.
So what? They are free to use any reference frame they like. Including ones where they were initially moving.
Just to add, it is often convenient to treat yourself as "at rest", but there is no actual requirement to do so. The observers may simply state that they are initially moving at 3m/s in the direction of one of them'd right arm. Or the other one's left leg. There is no experiment that can tell between these cases.
And why should they simply assume that they are initially at rest? Why privilege the frame they happen to start at rest in? Why not some random frame in which they move in some direction at some speed? Unless there is some test they can do to determine whether they are initially at rest (and there is not), why be so self-centered?
Ibix said:
Just to add, it is often convenient to treat yourself as "at rest", but no actual requirement to do so.
Indeed. You are free to go to the store, and not required to use a frame where the store comes to you.
Or "at what time does Oxford stop at this train", as Einstein is said to have asked.
  • · Replies 84 ·
  • · Replies 34 ·
  • · Replies 21 ·
