Synchronous Machine Homework Help: Calculating Generated Voltage and Power Angle
1 reply · 3K views
mayeh
1. A 4MVA, 13.3kV, 60Hz, 3 phase, delta-connected alternator has an effective resistance of 5.2 ohm/phase and a combined armature reactance of 54 ohm/phase. Determine the full-load generated voltage per phase, a. At unity pf, b. at 0.8 pf lagging, and at 0.866 leading pf.
2. A 750kVA, 2300V, delta-connected, 3-phase alternator has had open and short circuit tests performed and the following date were obtained:
Short Circuit test
Field current = 31.5A
Line current = rated
Open-circuit test
Field-current = 31.5A
Line voltage=1050V
The dc resistance across the terminals was measured at 0.38 ohm. Calculate the V.R. at 0.8pf lagging.
3. Calculate the open circuit votlage of a 3phase, star-connected alternator, 4 pole, 60Hz, 120 slots with each slot having 6 conductors in two layers. The machine is running at 1800rpm with a flux per pole of 125 milliWeber. The coil span is 12.
4. A single phase alternator, 50kVA, 460V supplies the rated load at 0.88 pf lagging. The dc resistance across the terminals is 0.5 ohm and the synchronous reactance is 2.5 ohm. Calculate the angle of the power.
no idea.
1. Homework Statement
I don't have any idea about this one. it wasn't taught to us. so please help.
Get a machines book and start reading.
