System of Equations: Solving U & V with Polynomials
The discussion focuses on solving a system of equations involving variables U and V. The provided equations are simplified to isolate U and V, leading to the solutions U=(s+1)/s^2 and V=(2s+1)/s^2. A participant struggles with complicated polynomials and seeks guidance on a general approach to solving such equations. They suggest using elimination and restructuring the equations for clarity. The conversation emphasizes the importance of showing work for effective assistance.
CarbonWater
sU-1+U-V=0
sV-2-U+V=(2/s)
N/A
the solutions are
U=(s+1)/s^2
V=(2s+1)/s^2
but I just keep getting complicated polynomials that I don't seem to be able to factor.
If someone could show me how this particular one was done and what a general approach is I would greatly appreciate it.
I was able to get the answers you posted. It may help to "clean" up the equations so that there is only one U and one V shown in each on the LHS, like this:
\begin{aligned}<br /> (s+1)U - V &amp;= 1 \\<br /> -U + (s+1)V &amp;= (2/s) + 2<br /> \end{aligned}
I used elimination by multiplying eq. 1 by s+1 and adding to eq. 2 to eliminate the V. In any event you have to show your work first, so either show us what you've got or try what I did, and we'll check it for you.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
