Calculating Work with Pressure in a System
  • Thread starter Thread starter georg gill
    Pressure System
Work in a system can be calculated using formulas involving pressure, area, and changes in height or volume, with a focus on the pressure from the surroundings. The distinction between reversible and irreversible work is crucial, as reversible work is calculated under constant pressure, typically atmospheric, while irreversible work presents challenges due to non-equilibrium conditions. In thermodynamics, expanding systems at higher pressures than atmospheric pressure are not in equilibrium, complicating work calculations. Despite this, the work done against atmospheric pressure can be equated to the work done by the expanding system. The confusion arises when considering how to apply pressure in different scenarios, but the same atmospheric pressure is used for both calculations due to the nature of work being done against or by the system.
georg gill
The work in a system is given by
F\cdot\Delta h
P\cdot A\cdot\Delta h
P\cdot \Delta V
when one calculate work one always uses pressure from surroundings. Why is it so. I get that work becomes linear then because p is constant but I thought that if one use Newtons third law that a system is standing still if forces are equal then work as a physical change would be done if p is larger in either system or surroundings. But if one look at force from system when p is larger in system why can't one use that to calculate work on surroundings?
Is this a thermodynamics question?
OK, I though it might be about chemical thermodynamics.
Now we know where we are going.
Thermodynamics allows two kinds of work - reversible work and irreversible work.
Your book was describing reversible work, whilst your example was about irreversible work.
We can always calculate the reversible work but usually calculation of irreversible work presents difficulty.
Chemical reactions are usually carried out at atmospheric pressure, often in open reaction vessels.
This allows us to make the statement of constant pressure (of the atmosphere). Work on a gas at constant pressure is reversible work and can be expressed by the formula
w = pdV
Which is what your book says.
On the other hand the system will be solid and/or liquid and the work irreversible.
An expanding system at higher pressure than atmospheric and where the pressure is gradually changing with the expansion is not in equilibrium.
Reversible systems are equilibrium systems
Irreversible systems are non equilibrium systems.
Luckily we can say that the ( reversible) work done against the atmosphere = the (irreversible) work done by the expaning system.
So we can calculate the process work that way.
It is just so that there is one thing I find really confusing. When system is expanding it works against the pressure of atmosphere so it has to move on that so use of pressure of atmosphere would make sense for me to calculate work. But when atmosphere is working on system I would think that the work it has to do to compress system is determinded by pressure in system therefore it is less per unit of volume then if system is pressing on atmosphere. How come one can use same pressure for both cases?
And I don't seem to get why my attempt of given an example was an irreversible example?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
