Taylor Series Expansion of Gravitational Field: Benefits & Uses
  • Context: Undergrad
  • Thread starter Thread starter scott_alexsk
The discussion revolves around the application of Taylor series expansion to the gravitational field, specifically in the context of a gravitational field of a ring. Participants explore the benefits and uses of this mathematical approach compared to other methods of analyzing asymptotic behavior.
  • Scott questions the necessity of using a Taylor series expansion for the gravitational field, suggesting that substituting a scaled factor and solving limits may suffice for understanding asymptotic behavior.
  • Scott provides the equation for the gravitational field of a ring and seeks clarification on the advantages of applying a Taylor series to this equation.
  • Scott concludes that he does not see the need for a Taylor expansion to determine asymptotic behavior, as he believes he can achieve this through other means.
  • Another participant requests more specificity regarding Scott's inquiry, indicating a need for further clarification in the discussion.
  • Scott references a previous question that appears similar, suggesting a continuity of thought on the topic within the forum.
The discussion remains unresolved, with Scott expressing skepticism about the utility of the Taylor series expansion while seeking further input from others. No consensus is reached on the necessity or benefits of the expansion.
Scott's understanding is based on his current methods for analyzing the gravitational field, which may not encompass all potential applications of Taylor series expansions. The discussion does not address specific limitations or assumptions inherent in the methods mentioned.
scott_alexsk
...to do a Taylor series expansion of an expression for the gravitational field? My physics teacher did a it few times on the board, but I do not understand how it gives me more information about the asymptotic behavior than substituting some scaled factor in for r, and then solving the limit as that dimensionless number goes to 0 or infinity. (i.e. finding the field of a uniform ring w/ radius d and distance r away from something, approaches the field of a point mass as r goes to infinity or d goes to zero). Maybe it is useful for something else?
Thanks,
-Scott
can you be a little more specific?
Sorry in advance for not using latex...
So if I have the equation for the gravitational field of a ring, g=G*m*z/(z^2+r^2)^1.5 (where z is the distance to some point along a line perpindicular to the center of the ring, and r is the radius of the ring), what useful thing can I get out of making a Taylor series for this equation?
I was saying before that I can already find information about the asymptotic behavior by setting v=r/z, and then plugging it into the equation and solving for the limit as v goes to zero (to show that the gravitational field of the ring approaches a point mass as the distance from it goes to infinity, or r goes to zero etc.) So I conclude from this that I don't need a Taylor expansion to determine the asymptotic behavior.
So just to rephrase, is there any reason why I would want to make a Taylor series expansion for the field function? My teacher certainly knows what he is doing, but I missed the point for doing the expansion.
Thanks,
-Scott
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 17 ·
15K
14K
10K
