Temperature vs Volume in an expanding gas
The problem involves the energy of a gas during an adiabatic expansion, described by the equation E = 3/2*NkT - aN2/V. The original poster seeks to determine the final temperature T2 after the gas expands from volume V1 to V2, while keeping certain variables constant.
  • The original poster expresses uncertainty about how to begin solving the problem and requests tips for proceeding. Some participants discuss the nature of adiabatic processes and how they relate to temperature and volume changes. Others suggest using the energy equation to explore the relationship between changes in energy, temperature, and volume.
Participants are exploring the implications of adiabatic cooling and discussing how to relate temperature changes to volume changes. There is a suggestion of a potential equation to use, but no consensus or resolution has been reached yet.
The original poster indicates a need for guidance without seeking a complete solution, and there is an acknowledgment of the complexity of relating temperature and volume in the context of the problem.
Fwahm
The energy of a gas is given by: E = 3/2*NkT-aN2/V, where E, N, k, and a are held constant (or are just constants). Volume V1 with temperature T1 expands adiabatically into V2. Determine T2.
All in part 1.
I'm not exactly sure how to start on this problem. I'm not asking for an answer, but some tips on how to proceed would be appreciated.
The system is naturally undergoing Adiabatic Cooling (as the Volume increases, the aN2/V term decreases, which means the 3/2*NkT term (and thus T) must also decrease for E to remain constant.
However, I don't know how to translate this into an equation for delta T/delta V, based on the other constants.
So if the only things that can vary are temperature and volume, it seems to me that if you just use
[tex] \Delta E=0=\frac{3}{2}Nk\Delta T-\frac{aN^2}{\Delta V}[/tex]
you can solve for [itex]\Delta T=T_2-T_1[/itex].
Thank you very much.
I really need some extra sleep tonight, I can't believe I missed such an easy solution.
  • · Replies 60 ·
11K
