some bloke
- 289
- 101
- TL;DR
- Just wanted a sanity check on my calculations of tennis balls in the ocean.
Hello all,
I indulged myself a curiosity today on the question of how much the sea levels would rise if we covered them with tennis balls.
(Don't ask why, because I don't know!)
Here's the rough breakdown of my calculations and assumptions:
1: Tennis balls are, on average, 6.7cm (0.067m) in diameter and weigh 59.2g. They are buoyant, so will displace 59.2g of water each.
2: They will tessellate in a single (magically stable) layer on the entire surface of the ocean, which for no apparent reason will stop having any waves etc. and become perfectly flat. This will essentially be a grid of hexagons, each hexagon with a ball inside.
3: The balls will be touching.
4: The density of the ocean water is 1.024.5kg/m^3
I realised that the effect would be repeated so I only need calculate for one hexagon to work out the total effect.
The area of a hexagon in which the diameter of a tennis ball can be inscribed is 0.00389m^2. I got this by breaking the hex into equilateral triangles, then splitting one to get a triangle with a known edge equal to the radius of the circle and a known angle of 60°, then used soh-cah-toa to get the edge length of the equilateral triangle, and thus the edge of the hexagon, which I used to calculate the area.
The volume of ocean water displaced by a 59.2g tennis ball is mass/density which is 5.778x10^-5 m^3
The height raised is therefore volume divided by the hex area, which is 0.0149m, or just under 1.5cm.
It'd take about 92,859,600,000,000,000 tennis balls.
The height raised makes sense, I just want to make sure I got my method correct (it's been a while since I opened the "Physics calculations" door in my brain!)
Thanks in advance!
Thanks in advance!
