Tension in a string at an angle
The discussion revolves around calculating the tension in a wire supporting a 2.15 kg picture at a 15-degree angle from the horizontal. The user initially attempted to solve the problem using the equation ΣF + (-ma) = 2Tsinθ - ma = 0, arriving at a tension of 38.1 N. However, it was pointed out that the correct approach involves using ΣFy = 0 for equilibrium, leading to the equation 2Tsinθ - mg = 0. The user later realized a calculation error due to using 9.18 instead of 9.81 for gravitational acceleration, which affected their result. Overall, the tension calculation is confirmed to be correct, with emphasis on ensuring accurate values in calculations.
BikeSmoth
A wire of negligible mass is used to hang a 2.15 kg picture. The ends of the wire are attached to the top 2 corners of the picture. Each end of the wire forms an angle of 15.0 degrees from the horizontal. What is the tension in the wire?
\SigmaF=ma
This is my latest and posiibly best attmept so far, but I don't have anyone to tell me if its right or not.
\SigmaF+(-ma)=2Tsin\theta-ma=0
2Tsin15-19.737=0
T=38.1N
It's correct
on which wire would you like the tension for?
Yes it looks correct to me.
Though you should put ΣFy=0 when the picture is in equilibrium and then rearrange to get T.
2Tsinθ-mg=0
there is only one wire with the picture connected at the two ends hanging down.
well it looks like my brilliant self put 9.18 instead of 9.81 in my calculator and subsequently got the question wrong. Man I hate online homework so much!
