Tensor and vector product for Quantum
7 replies · 2K views · last reply
MrMuscle
TL;DR
Hello, is there an operational order between tensor and matrix multiplications?
Hello, I am calculating the krauss operators to find the new density matrix after the interaction between environment and the qubit.
My question is: Is there an operational order between matrix multiplication and tensor product? Because apparently author is first applying I on |0> and X on |0> and obtain
I|0> =|0>, and X|0>=|1>. instead of first calculating U.
Then instead of making the tensor product he is distributing <0| .
Can someone please explain me why that's the case?
On attachment you can find more detailed explanation.
Thanks in advance!
246712
246711
  • Textbook page showing Example 12.1 on Kraus operators for a qubit measurement, with the worked solution computing A0 and A1 and the operator-sum representation of the density matrix.
MrMuscle said:
Summary: Hello, is there an operational order between tensor and matrix multiplications?
Please give a reference to the book or paper at which you are looking, as I am not sure about the notation used, and I need more context. For example, what does ##\left| 0_E \right>## mean? Something about a qbit zero and the environment ##E##?
You can't simply apply the ##I##-part of the operator product to ##|0_E \rangle##. This would lead to the invalid expression ##\langle 0_E|P_0 \otimes |0_E\rangle##.
Instead, he does
[tex]\langle 0_E|P_0 \otimes I |0_E\rangle + \langle 0_E|P_1 \otimes X|0_E\rangle \\<br /> P_0 \langle 0_E| I |0_E\rangle + P_1 \langle 0_E| X|0_E\rangle[/tex]
which is the proper way to do things if ##|0_E \rangle## and ##I## refer to the environement and ##P_0## and ##P_1## refer to the system (as George said, you should provide a tangible reference for context).
Hello, I hope the picture on the attachment helps!
It is from a book named "Quantum Computer Explained" by David McMahon.
Chapter 12, Quantum Noise and Error Correction
  • Textbook page showing Example 12.1 on Kraus operators: a single-qubit measurement unitary U = P0 ⊗ I + P1 ⊗ X, with its solution deriving A0 and A1 and the operator-sum representation, followed by the density operator expansion.
Instead, he does
Thanks for the answer. How can you take out P0 and P1?
kith said:
Are you familiar with the partial trace?
Kind of yes. I know how to calculate it but don't understand the concept behind.
Ok. Both the partial trace and your example involve expressions like
[tex]\langle \psi_E | A_S \otimes B_E | \psi_E \rangle[/tex]
(where ##S## stands for system and ##E## stands for environment).
On a first glance, this looks like an ordinary expectation value which can be evaluated by applying the operator / matrix to the vector followed by evaluating the inner product. On a second glance, this doesn't work because the dimensions don't match: the vector lives in the Hilbert space of the environment which has a smaller dimension than the composite space (at least for finite-dimensional Hilbert spaces) on which the operator acts. So it isn't a priori clear whether this expression is meaningful.
What we can say is that we shouldn't expect it to yielad a single number. A matrix which represents the operator ##A_S \otimes B_E## contains more rows than the number of components of the vector. So what we should expect is that each component gets multiplied by multiple matrix entries. This suggests that the result has to be again a matrix, albeit a smaller one.
I don't have authorative references handy but check these two links for how the partial trace works and why it is meaningful to define it this way:
http://www.thphy.uni-duesseldorf.de/~ls3/teaching/1515-QOQI/Additional/partial_trace.pdf
https://physics.stackexchange.com/q...ake-the-partial-trace-to-describe-a-subsystem
