Terahertz radiation converted into heat
  • Thread starter Thread starter jgrant333
    Heat Radiation
The discussion centers on the conversion of terahertz (THz) radiation into heat energy when it interacts with detector elements. The conversion percentage depends on the surface properties, particularly reflectivity, and moisture content, as these factors influence how much THz radiation is absorbed versus reflected. While all absorbed energy ultimately converts to heat, some may be re-radiated, complicating the calculation of heat conversion efficiency. The absorption efficiency of the dielectric medium also plays a crucial role in determining the outcome. Overall, understanding these dynamics is essential for accurately simulating THz radiation interactions.
jgrant333
Hello all.
Does anyone know what percentage of THz radiation is converted into heat energy? I'm thinking of the simple case where a beam of Thz radiation is incident upon some sort of detector element. The THz radiation can either be converted into kinetic energy (vibration of the molecules/atoms) or heat energy (there is not sufficient energy for inter atomic transitions etc.)
Has anyone tried to simulate such a situation?
Many thanks,
Science news on Phys.org
It depends on the surface. Like any other form of light the amount converted into heat is just 1-reflectivity. For these wavelengths there are lots of water bands so you would also have to be careful about any moisture on the surface.
Of course ii depends on the amount of light reflected.
However not all of the absorbed radiation will be converted into heat. It is this % of absorbed energy converted into heat I am after.
All the absorbed energy is converted into heat (where else could it go?)
Some of it will be re-radiated, assuming that the object behaves like a black body you can calculate what temperature it will heat up to and how much power will be re-radiated.
-In the short term some energy could be used to change the chemical nature of the surface (eg in cooking) but then anything else will just be heat.
It depends on the absorption efficiency of the dielectric medium.
I am a postgraduate majored in Terahertz. So if you have some difficult questions, you could talk with me about it! I will be glad to talk with you about my major.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
