Terminal Velocity and Bouyancy - F = kv
The discussion revolves around a physics problem involving a rock sinking in the ocean, influenced by gravity, buoyancy, and drag. The rock's terminal speed is calculated to be 3.02 m/s, derived from the balance of forces at terminal velocity. For the second part, the user struggles with integrating the net force equation to find depth, speed, and acceleration after 1.5 seconds, expressing difficulty with integration techniques. The acceleration equation is noted as a(t) = -4.90 N + 1.63s^-1 * v(t), indicating a relationship between acceleration and velocity. The user anticipates that solving part (b) will facilitate answering part (c) regarding the depth at 99.0% of terminal speed.
ultimateman
A rock of mass 0.400 kg is released from the surface and sinks in the ocean. As the rock descends it is acted upon by three forces: gravity, buoyancy, and drag. The buoyancy is an upward force equal to half its weight. Drag from the water can be modeled by F = kv, where k = 0.650 kg/s.
(a) Determine the terminal speed of the sinking rock.
(b) Determine its depth, speed, and acceleration 1.50 seconds after it is released.
(c) At what depth will it be at 99.0% of its terminal speed?
Net force (vertical), F = ma, F = kv
The solution to a) was easy enough.
Fnet = mg + FB + Fdrag
Fnet = -3.92 N + 1.96 N + Fdrag = 0 N (at terminal speed)
Fdrag = 1.96 N = 0.650 kg/s *vt
vt = 3.02m/s.
b) For calculating the depth, speed, and acceleration, I think I need to integrate the function of the net force with respect to time to get the equations for velocity and position. But I have not had much luck doing so because I am rusty on my integration.
The equation for the acceleration is
a(t) = -4.90 N + 1.63s-1 *v(t)
so I'm thinking
dv/dt = -4.90 N + 1.63s-1 *dx/dt
but then I get something like
dv = -4.90 N dt + 1.63s-1 *dx
and I don't know what to do with dx?
c) I'm thinking the answer for this part will be easy enough once I have the answer to b...
bump:smile:
so I'm thinking
Instead of dx/dt, try leaving that as v in this equation.
