Solve Golf Ball Trajectory: Time, Max Height, Distance, and Final Velocity
  • Thread starter Thread starter pooface
    Test
The discussion focuses on solving a projectile motion problem involving a golf ball struck from a height of 12 meters at a velocity of 40 m/s at a 30-degree angle. The calculations for time of flight, maximum height, horizontal distance, and final velocity were presented, with some corrections suggested regarding the maximum height calculation, which should not include the initial height when determining height above the plane. The final velocity was confirmed to be approximately 42.6 m/s, with an angle of -36.28 degrees below the horizontal. Participants emphasized the importance of using the correct formulas and accounting for the initial height in the calculations. Overall, the discussion provided insights into the application of projectile motion equations and the need for careful consideration of initial conditions.
pooface
TEST question!
Golf ball is struck at 12 m above the plain of a tee giving it a velocity of 40m/s at an angle of 30degrees.
a) find the time of flight
b) find max height above plane
c) horizontal distance to point of landing.
d) final velocity and angle.
Vox = 40cos30
Voy = 40sin30
a) -12 = 40sin30t + 0.5(-g)t^2
t=4.6084 seconds
b) disregarding the 12m elevation (which i will add later on).
0=40sin30t + 0.5(-g)t^2
t=4.0775s
t/2 = time at peak
y= - 0.5(-g)t^2 +12
= 32.387m
c)x =voxt
= 34.34(4.6084)
=158.25m
d)
-12= Vfy(4.6084) -0.5(-g)(4.6084)^2
Vfy = 25.21m/s
angle = arctan(vfy/vox) = -36.28deg
What is your question?
the a),b),c),d)
That's not a question.
What do you want?
What i meant was, confirmation of process.
Have i done this correctly? I want to check because I want to see if I screwed up a test question.
Thanks.
I'd have a look at b again. You can't assume that the maximum height comes at half the flight time because of the difference in elevation from where it was hit and where it lands.
I'd also try part d again. The velocity in the formula you're using there is an initial velocity.
part b) what i did was I neglected the initial height because i want to calculate the time of impact then half that time. Using this time, I get the height. but i would have to add the 12m back to get the real height.
I also could have used
Vfy=Voy+at
0=-20+(-9.81)t
which equals the same 2.039s.
part d) since vox is constant the final would be the same as well. so i just thought i would still name it vox.
Hey, I got a question. Isint this just direct applcations of projectile formulas.
Like: DeltaT= 2ViSintheta/g and so on?
Everything looks right to me except b). d) is correct... but a couple of little things are there...
For b), they want the height above the plane... not the height above the ground... so you wouldn't add 12...
also, you want: d = v1*t + (1/2)at^2 = 40sin30t + 0.5(-g)t^2... plug in t = 4.0755/2 will work.. gives 20.408m
you can also use: v2^2 = v1^2 + 2ad. v2 = 0, v1 = 40sin(30). so d = 40^2[sin(30)]^2/(2g) = 20.408m
Kurdt, the formula being used in part d, is d = vf*t - (1/2)at^2 which is a correct formula.
In part d, your Vfy should be -25.21 which is probably what you meant. So the final speed is sqrt[(-25.21)^2 + (34.34)^2] = 42.6 m/s. and the angle is right -36.28 degrees. ie: 36.28 degrees below the horizontal
21K
