Testing Heating Hot Dog in 900W Microwave Oven
The discussion revolves around the feasibility and safety of heating a hot dog using a magnetron from a 900W microwave oven, specifically addressing the design and setup of the heating chamber, including antenna placement and RF shielding considerations.
  • One participant inquires about the appropriateness of mounting the magnetron antenna on top or the side of a metal tube and whether a rotating reflector is necessary for wave distribution.
  • Another participant questions the overall RF shielding strategy and the experience level of the original poster regarding high-power RF systems.
  • Concerns are raised about the safety of working with magnetrons and high-voltage power supplies, with one participant expressing discomfort with high-powered microwave projects.
  • A participant suggests that the size of the tube may be too confined for effective microwave signal propagation and warns about uneven heating of the hot dog.
  • In response to safety concerns, the original poster mentions their background in RF transmitters and current work with high-voltage circuits, indicating a desire to learn more before proceeding.
  • Another participant proposes alternative heating methods, such as using a Pyrex tube with heater wire or induction heating, but acknowledges the limitations posed by the hot dog being in a plastic pouch.
  • The original poster considers increasing the dimensions of the heating chamber to improve microwave signal propagation and seeks resources for learning about microwave oven design.
  • A later reply provides a link to search results for microwave oven design but ultimately suggests closing the thread due to safety concerns and the need for professional guidance.
Participants express a mix of concerns regarding safety and technical feasibility, with no consensus on the best approach or design for the heating setup. The discussion remains unresolved, with differing opinions on the practicality and safety of the proposed project.
Participants highlight limitations related to RF shielding, the potential for RF leakage, and the dangers associated with high-voltage components. There are also unresolved questions about the effectiveness of the proposed heating chamber dimensions.
gstrom
Hello,
I want to do a test heating a hot dog in a tube using a Magnetron from a 900W Microwave oven. Before doing the test I would like to know if there is any reasons not to mount the magnetron antenna on top of the metal tube, or on the side. (Please see attached picture)
Also, will I need a rotating reflector to distribute the waves?
I am not shure this is the correct forum. If not, please advise the corect one.
Thanks,
gstrom said:
Hello,
Thanks,
Welcome to the PF. What does your overall shielded enclosure look like?
The tube is approx. 23cm long, with a diameter of 7cm.
That's not exactly what I was asking. I was asking what your RF shielding strategy is for the overall device. What experience do you have in the area of high-power RF shielding and testing?
Some of the questions you ask make me wonder if you should be playing with a magnetron or the 4000Vdc, 500mA+ power supply
Good observation…. Yes, I have no experience regarding using Magnetrons or shielding waves from a Magnetron. However, I worked with RF transmitters in the military, repaired BW and Color TVs, and are presently working with 600VAC, 300Amp circuits, so I think I know what I am up against, and that is why I found this forum to educate myself, before I hurt myself or anyone else.
The metal tube I am using will not have any holes as in a microwave door, so waves should not escape the tube. To prevent overheating I will install the thermo sensor from the microwave oven
Are there any other concerns I should consider? Any help will be greatly appreciated.
Thanks
gstrom
I think I see what you're attempting, but at best I don't think it would give the desired result.
First, the tube needs to reach a medium where the wave can propagate. Judging the tube from the size of the hot dog, your space is too confined to propagate a typical microwave oven signal (2.? GHz)
The next issue is that you're coupling REALLY well into the hot dog near the point of insertion. That means your energy is going to to heat the hot dog very quickly near the antenna and hardly at all as you move away.
Personally, I'm creeped out by these high powered microwave projects. A little RF leakage can injure you in the bone before you notice. Also, and not to be shunned, the power supplies on these will kill. I worked on TV's in college and developed offline motor drives and power supplies. None of that stuff is near as deadly as these microwave projects.
If you want to make the hot dog cooker of the age, I'd stick with something a little safer, like a Pyrex tube with heater wire and insulation, or maybe a stainless steel tube with induction heat, or a hot air design. These all have hot surfaces, so they can injury you, but you'll most likely come away with life and limb. That's a guarantee you won't get with high powered RF.
Best Wishes,
Mike
Thanks for the response and the warning. However, I have to figure out how to do it.
Induction heat or hot air does not work, since the hot dog being heated is in a plastic pouch.
To propagate the microwave signal I might be able to increase the chamber to 25cm long, 7cm wide and 25cm high, so the antenna is about 20cm above the hot dog. Will that work?
Can anyone direct me to where I can learn about microwave oven design?
Thanks,
gstrom
Thanks,
gstrom
Just googling microwave oven design gives you this hit list:
http://www.google.com/search?source...=1T4GGLL_enUS301US302&q=microwave+oven+design
I'm afraid that I need to close this thread. We can't be giving much more support on this via an Internet forum. Hopefully you can find a mentor or consultant in your area who can assist you with the design, and with the FCC and UL submittals.
9K
  • · Replies 19 ·
10K
  • · Replies 21 ·
