77 replies · 19K views
Homework Helper
- 30,567
- 7,542
First time it let's you down and you get to the train after it's left.Baluncore said:Then how could you know that the clock had stopped ?
- 1,258
- 755
For -1 second I thought it might be fun to work out the mathematical transform from t' to t where t' is the time on the upside down clock and t is the 'actual' time. But then said NO. And I don't even have a wifeanorlunda said:p.s. I thought it was a fun mental exercise to re-train my brain to tell time with the clock upside down. It wasn't difficult. But my wife was firm. She said, "NO."
Homework Helper
- 30,567
- 7,542
The high gearing to the second hand may explain why cheaper watches had a small seconds dial and not a sweep second (full diameter). I never considered that before.
JT Smith
- 499
- 671
Instead of removing the second hand maybe just cutting it down to a very short nub will fix the problem and yet still allow you to see if it's moving or not.
- 11,326
- 8,758
Didn't the experiment of hanging it upside down prove that it wasn't just a question of torque?JT Smith said:Instead of removing the second hand maybe just cutting it down to a very short nub will fix the problem and yet still allow you to see if it's moving or not.
Dullard
- 568
- 470
I have a cheap clock in my office that does exactly this when the batteries are shot. I always attributed it (strictly) to torque. The 'upside-down' result is unexpected. I'm wondering if that is an artifact of the (previous) excessive wear on the gear teeth at the 'stall' position. In other words: I would predict that a clock which has never operated in 'stall' for an extended time would not show a difference in performance when upside-down.
2025 Award
- 17,155
- 10,661
It could be wear to plastic on the uphill run, or redistribution of the lubricant.Dullard said:The 'upside-down' result is unexpected. I'm wondering if that is an artifact of the (previous) excessive wear on the gear teeth at the 'stall' position.
Rotating the second hand, relative to the gear that directly drives it, was not tested.
- 11,326
- 8,758
Did you read post #1? I started with an old clock stuck at 41s. I bought a new clock. It stuck at 41 s the first day.Dullard said:I'm wondering if that is an artifact of the (previous) excessive wear on the gear teeth at the 'stall' position.
JT Smith
- 499
- 671
Yes, but it could still be partly a question of torque. What is the explanation for why it doesn't stick when upside down?anorlunda said:Didn't the experiment of hanging it upside down prove that it wasn't just a question of torque?
If it's [edit: not] got to do with the hand itself then removing it or balancing it (or shortening it) won't fix it. But I'm not sure anybody really knows why it's sticking.
Could you try removing the second hand as an experiment?
Homework Helper
- 6,962
- 6,041
If you remove the second hand, it will not tell you anything.
On a slightly less technical plane, and as a person of some time on-planet, I offer a more worrisome supernatural explanation from a favored musician:
- It won't stop because torque from the final drive is sixtyfold more important.
- The second hand has a shaft attached...if removed nothing visible turns. Only an internal gear (maybe can see through the back?)
Dullard
- 568
- 470
I did. The '40 - 45 second' failure mode is common when available torque is 'just' insufficient. I don't believe that it's necessary (or correct) to assume that the failure of the 2 clocks have anything in common (except gravity). You apparently do? I do find the 'upside-down' behavior interesting.anorlunda said:Did you read post #1? I started with an old clock stuck at 41s. I bought a new clock. It stuck at 41 s the first day.
I'll assume that you didn't mean to be as offensive as your post reads.
Homework Helper
- 30,567
- 7,542
The second hand is very likely to be a friction fit on the shaft. Pull it off carefully and replace it 180 degrees different.
OR, take off the hand an put a tiny blob of paint on the shaft.
Do you still get the 41 minute effect?
Homework Helper
- 6,962
- 6,041
In my experience the second hand is rigidly attached to a ~1mmx8mm shaft which is friction fit through front hole into gear. Easy enough to pull straight out and reseat arbitrarily if you so desire. As mentioned (#26) I spent some time playing with these. With good bearings (from small Syma helicopter) these were just capable of rotation torque I needed when well balanced.sophiecentaur said:The second hand is very likely to be a friction fit on the shaft
JT Smith
- 499
- 671
You know for certain that removing it prevents the clock from stopping? That's what I wanted to know.hutchphd said:If you remove the second hand, it will not tell you anything.
2025 Award
- 17,155
- 10,661
Another test. Wait for the clock to stop at about 41 sec.
Then subject the clock to maximum torque and identify the stopping point by:
Start it again, as you place the clock on edge in front of you on a table.
Roll the clock slowly towards the left so seconds hand always points left.
What time does it stop? 41 sec = gear wear. Anytime = hand balance.
Next rotate seconds hand by 30 seconds and repeat the roll with seconds hand pointing left.
What time does it stop ? 11 sec = gear wear. Anytime = hand balance.
- 11,326
- 8,758
A apologize if it sounded offensive. I said that because I said the 2nd clock was new, and you wrote about excessive wear. Those two things would not be consistent.Dullard said:I'll assume that you didn't mean to be as offensive as your post reads.
Why additional roll tests? We already saw that with a 180 degree roll, it doesn't stop at all.Baluncore said:Another test.
2025 Award
- 17,155
- 10,661
That is one test, an enecdote. I feel uneasy about it.anorlunda said:Why additional roll tests? We already saw that with a 180 degree roll, it doesn't stop at all.
How long did the inverted test run?
Did you give it a fair chance to settle down and fail at maybe 11 or 41 sec?
You have branched out in the tests, but not closed the loop to verify a conclusion.
Things do not add up, so a firm conviction beyond reasonable doubt has not yet been made.
The hand position relative to the driven gear has not been changed. The shaft could be eccentric or bearings worn.
- 11,326
- 8,758
Let me see if I can do better. I no longer have the old clock, just the new one. I am not sure if I can locate the old weak battery. But I'll do some tests and post the raw data.Baluncore said:That is one test, an enecdote.
But I resist the idea worn parts. The thread was triggered because the new clock started getting stuck in the very first hour of use, and the symptoms seemed the same as the old clock with ~35k hours of use.
- 2,934
Many of these cheap clocks has movements like this, I think.
The 'axle' and 'bearing' of the stepper looks pretty lame and their prowess is probably susceptible to gravity.
The connecting gears may cause the asymmetry required for the no-problem-upside-down phenomenon.
That's all I can think of without having the thing in my hands.
- 11,326
- 8,758
OK, I promised to run more tests. It took me a while to locate that weak battery. But I found it and did 20 tests. The raw data is below in the chronological order I measured them. So here's the experiment.Baluncore said:That is one test, an enecdote. I feel uneasy about it.
- Put in the weak battery.
- Hang the clock with a certain angle. I express that angle in terms of the hour pointing up. Angle 12 is the normal orientation for a clock, angle 3 is 90 degrees on its side, angle 6 is 180 degrees upside down ...
- Measure how long for the second hand to get stuck. Some tests I terminated at 30 minutes. In those cases it might have continued indefinitely without sticking.
| Trial | Angle | Time Until Stuck |
| 1 | 12 | 30 seconds |
| 2 | 3 | > 30 minutes |
| 3 | 6 | > 30 minutes |
| 4 | 9 | 1 second |
| 5 | 12 | 100 seconds |
| 6 | 9 | 1 second |
| 7 | 11 | 100 seconds |
| 8 | 10 | 40 seconds |
| 9 | 8 | 30 seconds |
| 10 | 7 | 30 seconds |
| 11 | 6 | 7 seconds |
| 12 | 6 | 1 second |
| 13 | 5 | 20 seconds |
| 14 | 4 | 2 seconds |
| 15 | 3 | 40 seconds |
| 16 | 2 | 45 seconds |
| 17 | 1 | 45 seconds |
| 18 | 12 | 1 second |
| 19 | 9 | 45 seconds |
| 20 | 11 | 45 seconds |
Here is a plot, sorted by angle. I capped the maximum time to 600 seconds. Some tests were repeated, so there is more than one dot at the same angle.
Unfortunately, the data doesn't really support my theory that a flaw in the gears made it angle sensitive. There does seem to be slight angle sensitivity. However, I think the battery got weaker as I conducted the tests, and that swamped out other factors.
By the way, no matter the orientation angle of the clock. When the second hand did stick, it always did so in the 3rd quarter (180-270 degrees). That gives credence to the theory of increased torque to lift the weight of the second hand.
Note that this brand new clock started sticking on its very first day of service, so worn out parts should not be a factor.
NTL2009
- 637
- 393
Thanks for the update. Another test (if you are game), based on these results:
Add or subtract weight from the second hand so it is balanced, then try again. I'm actually surprised these hands (at least on large face clocks) are not balanced. Many styles of clock hands look like they were meant to be balanced (the short side of the hand is wide), and I think that is partially aesthetics, and partially historical. I'd bet that old large clocks had to be balanced to operate, but...
OK, I did a google image search, and it is not obvious that old, large clock hands were balanced. Some seem to be, but it's not universal, and doesn't appear to fully balance them. But that balance could also be inside the clock, behind the face.
- 11,326
- 8,758
I did one better. I removed the sweep second hand. Now, the clock runs indefinitely with the weak battery.NTL2009 said:Another test (if you are game), based on these results:
2025 Award
- 17,155
- 10,661
We have considered static balance, but not impedance and time matching through the seconds drive train. The seconds hand moves in steps. By adjusting the time constant of the seconds-hand mass system, the reflection from the hand impedance may oppose or support the next step in one second.
I would consider making the seconds hand into a balanced rotary pendulum with a period of one second. That might require the addition of a spring into the drive train to dominate the restoring force.
As the mechanism changes temperature the gear backlash may change which might change the hysteresis and reflection time.
- 11,326
- 8,758
I think I'm going to apply for a NSF grant to finance this research. Enough to provide for 3 grad students and a workshop. We can call it Studio 41.Baluncore said:I would consider making the seconds hand into a balanced rotary pendulum with a period of one second. That might require the addition of a spring into the drive train to dominate the restoring force.
2025 Award
- 17,155
- 10,661
Well, I understand that the wall clock is immersed in a flow of time, in the same way that a water wheel is immersed in a river. If your research group, Studio 41, can increase the efficiency of the clock, to the point that it slows down at a lower rate than the Earth's rotation slows due to tidal drag, then it should be possible to charge the clock battery with the difference. And that does not even require PM.anorlunda said:I think I'm going to apply for a NSF grant to finance this research.
Mentor
- 15,788
- 10,671
Perhaps this is where Douglas Adams got his answer to everything is 42 when clock stopped at 41.
https://en.wikipedia.org/wiki/42_(number)
versus 41
https://en.wikipedia.org/wiki/41_(number)
versus 41
Not anonymous
- 143
- 58
I can't believe it! I thought it was only my old wall clock that was jinxed by 40-41 seconds. Now I know it is was not alone :)
2025 Award
- 17,155
- 10,661
My wall clock sped up over the last week, then two days ago, it stopped at 40 seconds. I replaced the battery, and it is now keeping time again. I think clocks are organised and stop in sympathy.Not anonymous said:I can't believe it! I thought it was only my old wall clock that was jinxed by 40-41 seconds. Now I know it is was not alone :)
Homework Helper
- 30,567
- 7,542
The evidence is about clocks that have run for a long time. It won't only be to do with the angle of the second hand at the time it actually stops, I'm sure. Every rev of the second hand produces a maximum load at round about the same place on the dial - say 42s. As the movement passes this point the wear of the bearings and the gears is likely to be be highest here. (the whole mechanism is built as cheap as poss) So rotating the clock by 180 degrees will change the points on all the gears where the wear is now greatest. So, if the clock then keeps going on an almost flat battery, it would not be too surprising. With a new battery, it could be that it will then carry on until it now stops at (say) 12s, when a new set of worst wear coincides with failing to drag the second hand beyond the same value of around 225degrees relative to vertical.
So the answer to the universe and everything could, in fact be 225.
