2025 Award
- 17,119
- 10,628
Then how could you know that the clock had stopped ?sophiecentaur said:Or just remove it for ever.
First time it let's you down and you get to the train after it's left.Baluncore said:Then how could you know that the clock had stopped ?
For -1 second I thought it might be fun to work out the mathematical transform from t' to t where t' is the time on the upside down clock and t is the 'actual' time. But then said NO. And I don't even have a wifeanorlunda said:p.s. I thought it was a fun mental exercise to re-train my brain to tell time with the clock upside down. It wasn't difficult. But my wife was firm. She said, "NO."
Didn't the experiment of hanging it upside down prove that it wasn't just a question of torque?JT Smith said:Instead of removing the second hand maybe just cutting it down to a very short nub will fix the problem and yet still allow you to see if it's moving or not.
It could be wear to plastic on the uphill run, or redistribution of the lubricant.Dullard said:The 'upside-down' result is unexpected. I'm wondering if that is an artifact of the (previous) excessive wear on the gear teeth at the 'stall' position.
Did you read post #1? I started with an old clock stuck at 41s. I bought a new clock. It stuck at 41 s the first day.Dullard said:I'm wondering if that is an artifact of the (previous) excessive wear on the gear teeth at the 'stall' position.
Yes, but it could still be partly a question of torque. What is the explanation for why it doesn't stick when upside down?anorlunda said:Didn't the experiment of hanging it upside down prove that it wasn't just a question of torque?
I did. The '40 - 45 second' failure mode is common when available torque is 'just' insufficient. I don't believe that it's necessary (or correct) to assume that the failure of the 2 clocks have anything in common (except gravity). You apparently do? I do find the 'upside-down' behavior interesting.anorlunda said:Did you read post #1? I started with an old clock stuck at 41s. I bought a new clock. It stuck at 41 s the first day.
In my experience the second hand is rigidly attached to a ~1mmx8mm shaft which is friction fit through front hole into gear. Easy enough to pull straight out and reseat arbitrarily if you so desire. As mentioned (#26) I spent some time playing with these. With good bearings (from small Syma helicopter) these were just capable of rotation torque I needed when well balanced.sophiecentaur said:The second hand is very likely to be a friction fit on the shaft
You know for certain that removing it prevents the clock from stopping? That's what I wanted to know.hutchphd said:If you remove the second hand, it will not tell you anything.
- It won't stop because torque from the final drive is sixtyfold more important.
A apologize if it sounded offensive. I said that because I said the 2nd clock was new, and you wrote about excessive wear. Those two things would not be consistent.Dullard said:I'll assume that you didn't mean to be as offensive as your post reads.
Why additional roll tests? We already saw that with a 180 degree roll, it doesn't stop at all.Baluncore said:Another test.
That is one test, an enecdote. I feel uneasy about it.anorlunda said:Why additional roll tests? We already saw that with a 180 degree roll, it doesn't stop at all.
Let me see if I can do better. I no longer have the old clock, just the new one. I am not sure if I can locate the old weak battery. But I'll do some tests and post the raw data.Baluncore said:That is one test, an enecdote.
OK, I promised to run more tests. It took me a while to locate that weak battery. But I found it and did 20 tests. The raw data is below in the chronological order I measured them. So here's the experiment.Baluncore said:That is one test, an enecdote. I feel uneasy about it.
How long did the inverted test run?
Did you give it a fair chance to settle down and fail at maybe 11 or 41 sec?
| Trial | Angle | Time Until Stuck |
| 1 | 12 | 30 seconds |
| 2 | 3 | > 30 minutes |
| 3 | 6 | > 30 minutes |
| 4 | 9 | 1 second |
| 5 | 12 | 100 seconds |
| 6 | 9 | 1 second |
| 7 | 11 | 100 seconds |
| 8 | 10 | 40 seconds |
| 9 | 8 | 30 seconds |
| 10 | 7 | 30 seconds |
| 11 | 6 | 7 seconds |
| 12 | 6 | 1 second |
| 13 | 5 | 20 seconds |
| 14 | 4 | 2 seconds |
| 15 | 3 | 40 seconds |
| 16 | 2 | 45 seconds |
| 17 | 1 | 45 seconds |
| 18 | 12 | 1 second |
| 19 | 9 | 45 seconds |
| 20 | 11 | 45 seconds |
I did one better. I removed the sweep second hand. Now, the clock runs indefinitely with the weak battery.NTL2009 said:Another test (if you are game), based on these results:
Add or subtract weight from the second hand so it is balanced, then try again.
I think I'm going to apply for a NSF grant to finance this research. Enough to provide for 3 grad students and a workshop. We can call it Studio 41.Baluncore said:I would consider making the seconds hand into a balanced rotary pendulum with a period of one second. That might require the addition of a spring into the drive train to dominate the restoring force.
Well, I understand that the wall clock is immersed in a flow of time, in the same way that a water wheel is immersed in a river. If your research group, Studio 41, can increase the efficiency of the clock, to the point that it slows down at a lower rate than the Earth's rotation slows due to tidal drag, then it should be possible to charge the clock battery with the difference. And that does not even require PM.anorlunda said:I think I'm going to apply for a NSF grant to finance this research.
My wall clock sped up over the last week, then two days ago, it stopped at 40 seconds. I replaced the battery, and it is now keeping time again. I think clocks are organised and stop in sympathy.Not anonymous said:I can't believe it! I thought it was only my old wall clock that was jinxed by 40-41 seconds. Now I know it is was not alone :)
