The back EMF of a DC motor spinning at full speed
The discussion revolves around calculating the back EMF of a DC motor operating at full speed, given the armature resistance, supply voltage, and current draw. Participants explore the relationship between the back EMF and the line voltage, as well as the implications of these values in the context of DC motor operation.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants attempt to relate the back EMF to the line voltage and the current through the motor's resistance. Questions arise regarding the definitions of peak and average values, as well as the role of back EMF in opposing the supply voltage.
There is an ongoing exploration of the relationship between the line voltage, back EMF, and the current through the motor. Some participants provide insights into the nature of back EMF in a DC motor, while others express confusion about the concepts of peak and average values. A potential formula for calculating back EMF has been suggested, but no consensus has been reached on its application.
Participants are navigating the complexities of DC motor operation, including the effects of back EMF and the significance of given values such as line voltage and armature resistance. There is a noted lack of clarity regarding the definitions of peak and average values in this context.
OmegaFury
The resistance of the armature windings of a DC motor is 5Ω. The motor is connected to a 120V line. When the motor is spinning at full speed, it draws a current of 4A. The back EMF at full speed is:
Pav=\frac{1}{2}I2peakR
Pav=\frac{1}{2}εpeakIpeak
=\frac{1}{2}(4A)25Ω=40W
2Pav/Ipeakpeak
2(40W)/4A=20V.
This isn't correct. I also didn't know what to do with the 120V line.
Presumably in the motor the back EMF opposes the line voltage. That reduces the net voltage that appears across the winding resistance, and it's the net voltage that drives the current through the winding resistance.
Does that mean that the back emf is equal to the line voltage minus the peak emf?
Peak emf? At constant rotation rate ("spinning at full speed") the back emf will be a constant value.
I don't follow. I honestly don't fully understand what peak values are. Or rms values for that matter. They just come up in formulas for average power... All I know is that it has something to do with an alternating current, and they arise from moving electrical charges that periodically switch direction. It supposedly has some advantage over a direct, one directional current, but what that advantage is and why, I have no clue.
Here you're dealing with a DC motor. The supply voltage is DC. You can expect the back emf to be a constant DC value as well so long as RPM is constant.
If the supply voltage is V and the back emf is E, and the current is I and the coil resistance is R, (whew!), then if E opposes V, what is the current? What formula would you write for the net potential if "E opposes V"?
The current would be 120V/5Ω= 24A
...E= -V?
Nope. Because 120V is the line voltage, not the net voltage across the coil. The back EMF opposes the line voltage. Also, you're GIVEN the current...
...E= -V?
Nope. That would make the net potential across the coil zero, so that no current would flow.
Perhaps a simple diagram will help:
If you treat the EMF voltage E as a simple DC Voltage supply, what would the equation for Ia equal? You can then move that around to solve for E.
Okay. So. You meant find the voltage in the motor. I suppose that would be V=IR=4A x 5Ω=20V.
Umm... E= Vline-Vmotor
Yes, that looks good. So E = ?
gneill said:
yes, that looks good. So e = ?
120V-20V= 100V
That took me forever X__X
OmegaFury said:
120V-20V= 100V
Perhaps. But then, you're probably going to remember it :smile:
Lol. Very true. Frustration is well-remembered while ease is a fleeting memory.
9K
  • · Replies 16 ·
  • · Replies 19 ·
