What Are the Basic Functions and Applications of Calculus in Real Life?
  • Thread starter Thread starter Mattius_
    Calculus Function
Calculus is fundamentally about understanding "instantaneous change," allowing for the calculation of rates like speed and acceleration through limits and approximations. It operates through various branches, with no single "basic mode" of operation, as each problem requires a tailored approach. Calculus is closely linked to Cartesian geometry, particularly in applications like integration, which is essential for solving real-life problems involving variable forces, such as calculating work. It provides precise approximations for complex equations that cannot be solved using simple algebra. Overall, calculus is crucial for applications in physics and other fields where change and variability are key factors.
Mattius_
can someone tell me
A) the basic function of calculus
B) the basic mode of operation in calculus when solving a problem
C) if calculus is intergrated with Euclidian geometry
i am not incredibly math friendly but my questions didnt really warrant any intense mathematical explanation...
Mathematics news on Phys.org
A very strangely phrased request! If you are not friendly (to math or whatever), could tell us why your question really warrants ANY explanation?
I take it when you say "the basic function of calculus" you mean "application" rather than a mathematical function (I puzzled over that for a moment!). Basically, calculus allows us to define and work with "instantaneous change". Here's an example I've used before: Imagine being in a spaceship well above the ecliptic: take a photo that shows includes both the sun and the earth. Of course, from a single, static photgraph, you CAN'T find the speed of the Earth around the sun, much less the acceleration: to calculate the speed you need two photos: measure the distance the Earth has moved and divide by the time between the photos to find the average speed between the two. To find acceleration you would need a third photo so you could find two different speeds and find the change in speed.
Yet, you COULD measure the distance from the sun to the Earth from a single photo, then use Newton's gravitational formula to find the force. But F= ma. We are able get the left side of this from a single photo but not the right!
Calculus allows us to define "instantaneous change" (speed AT a specific instant) and make sense of this.
I have no idea what you mean by "basic mode".
Yes, calculus is based on Euclidean geometry. The "integration" is through Cartesian geometry.
The functions of calculus in practice include finding rate of change at an instantaneous moment and finding the area under curves. There are many different practical applications to theoretical physics, for example the derivation of equations, and complex numbers (real and imaginary numbers, which provide answers to equations where real numbers do not suffice).
Calculus itself is based pretty much on "limits" and limiting values. This basically means that a variable tends towards a particular value, without ever actually hitting that value. This allows for an almost 100% precise approximation to many questions, which otherwise cannot be answered.
There is no "basic mode of operation" in calculus; there are simply so many branches that every problem requires a different approach.
As for your third question, there are parts of calculus which link with Euclidian geometry, but the majority links in more with Cartesian geometry (integration especially).
One application of using Calculus for real life situations is finding work. If you take a non-Calculus based Physics course, they'll tell you that work = force(displacement). This great in the ideal world but it doesn't work in real life situations because the force will be variable. Here's where Calculus comes into place.
What you want to do is find the interval where you are doing the work and then you want to take a small portion of that interval, and find the work perfomed over that portion. Then you want to add up each portion's worth of work and then you obtain the work performed with a variable force. The addition is replaced with a definite integral. Your limits of integration will be your interval and you integrate the force over that interval.
You mean if I learn calculus it will easier for me to find work?
In general if one has a formula which, as long as things remain constant, involves a division, for variables, it becomes a derivative:
example: speed = distance/time becomes derivative of distance with respect to time.
If one has a formula which, as long as things remain constant, involves a product, for variables, it becomes and integral.
example: area of a rectangle (height above x-axis is a constant) is
hw. If the height varies, we integrate height with respect to the base variable.
other example: work as Sting said.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
