Rob060870 said:
thanks,
also I am interested to hear that the expansion rate in our universe is very close to critical so that its just enough not to collapse does that mean that if our universe wasnt expanding at an ever increasing rate then we could have already started the big crunch?(i know it also depends on how much total matter is in the universe) also would that mean time flows in reverse?
I think "time flows in reverse" isn't really a useful notion at this point, so I'll just propose "No" as my answer for the last question and consider the notions of expansion, reversing expansion to a crunch, and being "critical".
As for expansion rate being "critical"; this isn't actually much of an issue these days, with the discovery of dark energy. Our expansion rate isn't actually "critical", I think.
This is older terminology which was popular when the big question was whether there was enough matter to reverse the expansion and bring about a big crunch, or whether the expansion would continue for ever. That was how the question was discussed in the early 1990s and earlier. Back then, the expansion of the universe was considered to be moderated by the effects of matter, and of curvature. There was no Λ, no cosmological constant.
For any given matter density, there was a critical expansion rate which would mean that the universe would expand forever. This was also the zero curvature case. Less density for the critical expansion rate, or more rapid expansion for the critical density, would give an "open" universe which expanded forever, and more density would give a "closed" universe.
In older accounts of the Big Bang, you often find three simple alternatives considered. They are:
(1) Closed universe (with no Λ)
Assuming no Λ, this case could be identified four ways.
- The universe is closed. That is, curvature is positive, and space is finite (though very big). The available volume of the universe is finite but without any edge, just like the available area of the Earth's surface is finite but without any edge. It curves back on itself.
- Density is super-critical. That is, there is more matter in the universe than is required to bring expansion to a stop.
- Expansion is sub-critical. That is, the expansion rate is too slow to allow the expansion to continue indefinitely.
- The universe will collapse into a Big Crunch. Eventually, expansion will slow, stop and reverse. This is not a reversal of time. It just means things start to compress together rather than expand apart, with a singularity in the future when everything is compressed with arbitrary density.
Assuming no Λ, anyone of the four qualities implies the other three.
(2) Open universe (with no Λ)
- The universe is open. That is, curvature is infinite, and space is infinite.
- Density is sub-critical. That is, there is not enough matter in the universe to bring expansion to a stop.
- Expansion is super-critical. That is, the expansion rate is too fast to ever be brought to a halt.
- The universe will expand forever.
(3) Flat universe (with no Λ)
- The universe is flat. That is, space is infinite, with no curvature. Space looks a bit like an infinite cartesian grid R3.
- Density is critical. That is, there is just enough matter in the universe to slow expansion down to as slow as you like, without ever quite coming to a stop.
- Expansion is critical. That is, the expansion rate is just fast enough to avoid ever being halted.
- The universe will expand forever, but more and more slowly over time, without limit.
(4) Dark energy (Λ)
In the 1990s, a fourth alternative came back into consideration... the cosmological constant, or dark energy, or a kind of pressure that counteracts the tendency of gravity to pull things back together, and rather tends to drive them apart, accelerating the rate of expansion.
This suddenly makes all the older descriptions confusing, because it is no longer the case that being open/closed/flat is the same as being sub-critical/critical/super-critical.
You can represent the universe with three qualities, any two of which gives the other. There's the amount of matter. There's the amount of dark energy. And there's the amount of curvature. Strictly speaking I am telling you lies here, because you can get more variations than this, but this simple case is widely used, as the ΛCDM model of the universe.
For any given rate of expansion, there is a certain critical density, which corresponds precisely to the critical matter density of the older "flat" universe case without Λ. So for the given rate of expansion H
0, there are three numbers considered, which have to add up to 1, and which are all dimensionless ratios: fractions of a critical density.
- Ωm. The amount of matter, as a fraction of critical density. We think this is very close to 0.27 in the current universe, and most of this is dark matter.
- ΩΛ. The amount of dark energy, as a fraction of critical. (Critical being the amount to give a flat universe without any matter.) We think this is very close to 0.73 in the current universe.
- Ωk. The contribution of curvature. By definition, it has to be 1 - Ωm - Ωk. It is 0 for a flat universe, negative for a closed (finite) universe with positive curvature; and positive for an open (infinite) universe with negative curvature. The sign of curvature is the opposite of the sign of Ωk. We think this is very close to 0 in the current universe.
Hence these days, you are much more likely to hear cosmologists wondering why the universe is flat, rather than why the expansion rate is critical. Without going into all the details, dark energy means that the expansion rather
isn't critical. It is, apparently, accelerating, and will continue to accelerate indefinitely. Flatness is usually explained by appealing to an inflationary epoch in the very early universe... another topic in its own right.
You may enjoy the following diagram
from
cosmology lectures by James Schombert at Uni of Oregon. Horizontal blue lines give constant Ω
k, the red lines give constant Ω
m and the green lines give constant Ω
Λ. Our universe is currently located on the diagram at about ΛCDM. The two other cases are SCDM, for case (3) above, the flat universe with critical matter density and no Λ; and OCDM, for case (2) above, the open universe with no Λ.
Homework. Locate case (1) on the diagram.
