Proving the Binomial Theorem with Induction
The discussion centers on proving the binomial theorem using mathematical induction. The initial approach involves demonstrating the theorem's validity for n=1 and assuming it holds for all n less than n_0, with the goal of proving it for n=n_0+1. The user expresses confusion about completing the proof and seeks guidance. A suggestion is made to utilize Pascal's Triangle, emphasizing that the inductive hypothesis for exponent k can be leveraged to show it holds for k+1 by manipulating the binomial expansion. This method aligns with the approach outlined on the referenced PlanetMath link.
Cincinnatus
It seems like this shouldn't be too difficult and yet I'm stumped.
I am trying to prove the binomial theorem.
(x+y)^n = the sum from k=0 to n of (x^k)*(y^n-k)*(The binomial coefficient n,k)
Sorry, about the notation...
Anyway, I figure the best way to go about proving this is by induction.
It is easy to show that its true for n=1.
Then I assume that there exists an n_0 such that it is true for all n < n_0.
Now I want to show that the existence of this n_0 implies that the proposition is also true for n=n_0+1.
This is where I get stuck...
My question is, is this even the best way to go about proving this? If so, how can I finish the proof?
Maybe it would be better to give me a hint so I can figure it out on my own...
Mathematics news on Phys.org
http://planetmath.org/encyclopedia/InductiveProofOfBinomialTheorem.html
Go to the above link
What you need to do is look at Pascal's Triangle. You should be aware of the simple procedure required for you to recreate the triangle yourself. You have to show that the number in one spot is equal to the sum of the two numbers above it. Now assume as your inductive hypothesis that the binomial expansion works for the exponent k. To prove that it works for exponent k+1, multiply the assumed expansion for k by just (a - b) (or whatever you are using for the base where the exponent is k), and use the facts just mentioned about Pascal's triangle to show that the expansion takes the desired form for k+1 as well.
EDIT: which is precisely what PlanetMath seems to tell you. :redface:
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
