Show me a derivation of the BKE
  • Thread starter Thread starter abercrombiems02
    Derivation
The discussion centers on deriving the Basic Kinematic Equation (BKE), which relates the inertial frame (e) and the working frame (u) through angular velocity (omega) and the cross product. A participant acknowledges the simplicity of the solution in single rotation problems but seeks a formal proof. They mention scanning their old dynamics notes to share the derivation, despite the poor quality of the PDF. Another participant discovers a more geometrical proof but lacks a scanner to share it for verification. The conversation highlights the collaborative effort to clarify and validate the derivation of the BKE.
abercrombiems02
For any of you advanced dynamics people, can you please show me a derivation of the BKE. (Basic Kinematic Equation)
The BKE is...
e d/dt(Vector) = u d/dt(Vector) + omega between e and u X (Vector)
sometimes an additional term is added which is the linear velocity between the frames but for some simplicity let's assume this is zero.
e is the inertial frame
and u is the working frame
omega is the angular velocity
X is the cross product operator
I know just by looking at a simple single rotation problem, the solution is trivial but does anyone know of a formal proof?
I do, but I think it will take me a month of Sundays to write here. Let me see if I can scan in my old dynamics notes from school. Give me a bit!
Thanks, take your time, I'm in no rush!
Here we go. I had to scan it in from my Dynamics class notes. The pdf is a bit rough on the quality side. If you can't read it, let me know and I'll e-mail you the scan.
thanks alot! This works perfectly. I actually found a more geometrical way to prove it with the few extra hours i had to spare today. Unfortunately, I don't have a scanner to show anyone to ensure correctness. Perhaps when I get back to school I can scan it in and have someone verify that my method is correct. Thanks again!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
