Is the Cosmological Constant Truly Constant?
jfy4
Hi,
I am wondering if the cosmological constant is a constant in the sense that it can only have one value, ie some constant element of the reals, or if it can be a scalar function too dependent on the coordinate variables, eg \Lambda(r,t).
Thanks in advance,
Usually it's constant to maintain that the divergence of the stress-energy tensor is zero.
I think there are ways of adding it not to the field equations, but to the action, and varying with respect to it, to also maintain energy conservation. http://arxiv.org/abs/gr-qc/0505128
That makes sense. If I may, would the satisfaction of
\nabla_{\beta}\left( T^{\alpha\beta}-g^{\alpha\beta}\Lambda\right)=0
justify the inclusion of a cosmological constant that was a scalar function?
Do you mean something like the potential of a scalar field forming part of the stress-energy tensor of matter (http://ned.ipac.caltech.edu/level5/Carroll2/Carroll1_3.html" )?
Thanks for your help,
I think this answers my question.
Classically, then, the effective cosmological constant is the sum of a bare term \Lambda_0 and the potential energy V(\phi), where the latter may change with time as the universe passes through different phases.
This sounds like it is ok to include a cosmological constant of the form
\Lambda(x_{\alpha})=\Lambda_0+V\,[\phi(x_{\alpha})]
that consists of an initial cosmological constant, \Lambda_0, summed with a scalar function V. Have I interpreted this correctly?
jfy4 said:
Hi,
Thanks in advance,
The LHS of the Einstein equation should be divergenceless, because the right hand side is (energy momentum conservation). This brings one to the addition of a term
<br /> \Lambda g^{\mu\nu} \ \ \rightarrow \nabla_{\mu}(\Lambda g^{\mu\nu}) = \nabla^{\nu}\Lambda = 0<br />
So,
<br /> \partial_{\mu} \Lambda = 0<br />
Hence, lambda must be a constant.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
