The Identity Crisis of i: Is i truly unique compared to -i?
  • Context: Graduate
  • Thread starter Thread starter Yayness
    Definition
The discussion centers on the identity and uniqueness of the imaginary unit "i" compared to "-i". Participants argue that both "i" and "-i" share identical mathematical properties, such as addition, subtraction, multiplication, and division, as well as their roles in Euler's formula and the Mandelbrot set. The distinction between them is primarily based on convention, as both can be defined as the square root of -1. The conversation highlights that while "i" has a positive imaginary part and "-i" has a negative one, this difference is arbitrary and does not affect their mathematical behavior.
  • Understanding of complex numbers and their properties
  • Familiarity with Euler's formula and its applications
  • Knowledge of the Mandelbrot set and its significance in complex analysis
  • Basic concepts of ordered pairs and their operations in mathematics
  • Explore the properties of complex conjugates in complex analysis
  • Study the implications of defining complex numbers in different mathematical frameworks
  • Research the role of the imaginary unit in various mathematical theorems and proofs
  • Investigate the Hamiltonian formalism and its applications in physics and mathematics
Mathematicians, physics students, and anyone interested in complex analysis and the foundational concepts of imaginary numbers.
  • #31
other than that they are quantitatively opposite,
That is why they are not equivalent, qualitatively or something else.
there is no difference between i and -i. they both have equal claim to squaring to be -1. and there is little else you can say about their properties
So?
Existence of some sort of sameness does not imply equivalence or identity.
  • #32
So?
"Equivalence" and identity are not the same thing. Equivalence is "the existence of some sort of sameness" i.e. the existence of an isomorphism. Hence we speak of equivalence relations (between different objects) and equivalence classes. It has a formal meaning in mathematics and that meaning does indeed apply to the conjugation isomorphism in the complex division algebra.
But this argument is silly ****Because**** you and the others have not established within which context you are referring to i and complex numbers. Until you carefully establish such a context questions of "what ____ really means" or "really is defined to be" are subject to reinterpretation and you can argue in circles, never getting anywhere.
  • #33
I did that in my first post.
  • #34
Isn't "sameness" a bit ambiguous? I prefer the following formal definitions of equivalence and equality: Equivalence is used when objects are equivalent with respect to some defined equivalence relation, may it be an isomorphism, modulo class, etc. Equality however in set theory is set equality, and thus equality is an example of an equivalence. E.g. two numbers are equal because equality refers to some construction of the numbers in set theory. (1=1 because {{}}={{}} )
  • #35
Yawn.
Take a field A , like the complex numbers and another one B, for simplicity its mirror image, so that a mapping exists between a+ib in A to a-ib in B.
Here, "i" in A is equivalent to "-i" in B, but "i" and "-i" are not "qualitatively equivalent" within anyone of the systems.
It is precisely because in BOTH fields A and B that elements within each of them retain their uniqueness from other elements that there exists a bijection from A on B or vice versa.
  • #36
arildno said:
Yawn.
ya know, you can sort of arrogantly dismiss jambaugh, but that posturing does you no good. he is correct (almost, i might have a semantic bone to pick) and you are wrong.
you may hide behind your Science Adviser badge, if you want (it's no big deal, many of us have been there), but you're still wrong.
yes, they are. they are qualitatively equivalent. they have equivalent quality. there is no quality in which they differ. and, since they are not the same number, they are not quantitatively equivalent. seems like you could make use of a dictionary.
sure, and it's a simple 1-to-1 mapping. big deal.
doesn't say anything about the qualitative properties of +i and -i. you name a single property (using words) that +i has that -i does not also have (or vise-versa). conventions like "clockwise" or "left" do not count. except for biological accidents of nature (or some QM issue regarding parity violation and the weak interaction) "left" has the same quality as "right", although they point in opposite directions. their only difference is one of convention.
name one qualitative property that differs between +i and -i, smarty pants.
  • #37
You name a bunch of this which are allowed and a bunch of things which are disallowed, the problem here is that the "sameness" between i and -i is ill-defined. You must in mathematical terms define what you mean by "qualitative property", and what it means that i and -i share it.
  • #38
Sigh, I was hoping you would all work this out amongst yourselves.
I second this. I hereby forbid any further discussion in this thread trying to make assertions about ill-defined terminology.
  • #39
i'm still waiting for a single property (described with words and without arbitrary convention) that +i has and -i does not.
off hand i can name two properties that they have in common:
1) they are both outside the set of real numbers.
2) squaring either gets you -1.
i want to hear someone identify (with words) that "+i has this [such-and-such] mathematical property (as opposed to a notational property) and -i does not."
ill-defined, Hurk?
  • #40
i is the only solution for x in the equation x=i.
  • #41
-i is the only solution for x in the equation x=-i. :biggrin:
Please note:
In mathematics, you don't have to initially understand anything, you first just "get used to it."
  • #42
A notational property is a mathematical property. I'd even argue they are equivalent.
Anyway, 1 = 1 is surely a notational and a mathematical property of 1.
The whole "equivalence" between i and -i can be summed up in the trivial assertion that R[-i] and R are isomorphic as fields. But this is all relative; sqrt(2) and -sqrt(2) are similarly "equivalent" in, say, Q[sqrt(2)]. I can argue all day long that there is no "qualitative" difference between sqrt(2) and -sqrt(2), but as you can see it is entirely meaningless.
  • #43
That will have to wait until you explain what you mean by "mathematical property" and by "notational property".
  • #44
Correct. :smile:
If this was the only basis for the asserted concept of "qualitatively equivalent", then all numbers are qualitatively equivalent to each other, notationally, mathematically, and decidedly propertarially so.
And therefore, the whole concept can be dismissed as..meaningless.
The defenders of the concept have yet to bring some solid mental shape to this amorphous beast.
  • #45
Here's one:
\sqrt{i} = \frac{1+i}{\sqrt{2}}
\sqrt{-i} = \frac{1-i}{\sqrt{2}}
\sqrt{i} - \sqrt{-i} = \sqrt{2}i
That last fact wouldn't be true if i and -i were no different.
  • #46
Char. Limit said:
Here's one:
i am taking \sqrt{2} to be 0 < \sqrt{2}
this is true for +i :
\frac{1+i}{\sqrt{2}} - \frac{1-i}{\sqrt{2}} = \sqrt{2}(i)
are you saying that if you were to swap every occurrence of +i with -i and vise versa that this isn't true?
\frac{1-i}{\sqrt{2}} - \frac{1+i}{\sqrt{2}} = \sqrt{2}(-i)
i don't get your point.
  • #47
arildno said:
Yawn.
The conjugation involution is an automorphism of the complex number field. (That's a mapping from A to A if you like).
Re: the other post. You did not "establish a context" in your first post. You mentioned Hamiltonian formalisms and proceeded with one of the many equivalent constructions of the complex number field. There are others and the Hamiltonian formulation doesn't care which. By context I mean the epistemological context by which you can determine if a claim (made in this thread) is true or false.
For example in a physical context there ain't no "i" as such. QM is a real theory and you can carry out the whole of it without ever mentioning complex numbers. They are just a handy shortcut through many a tedious definition and calculation. Classical physics likewise. They provide insufficient context to answer these questions.
Now within mathematics one can (again I mention this) consider i in the context of a group, a vector (e.g. an ordered pair), a field, a division ring, a clifford algebra,... in all those contexts i and -i are equivalent (in the mathematical sense of the existence of an automorphic mapping between them, namely *). Of course they are not equal as that would imply i = 0 and I think it is clear no one here things they are the same identical object (in whatever context).
[To others invoking radical notation]
People write \sqrt{-1} as if it settles the matter but the notation has built into it a convention. The "principle square root" is one of the square roots picked by convention to be "the principle one". One may change the convention so what we formerly though of as i is identical with -\sqrt{-1}.
  • #48
And you will wait until doomsday as they are isomorphic under * so there is none. That fact settles this particular matter entirely.
