How Does the Dirac Delta Function Solve the Differential Equation?
The discussion centers on solving the differential equation Ay'' + By' + Cy = f(t) with initial conditions y(0) = y'(0) = 0 using convolution. The function f(t) is defined as n for a specific interval and the solution is derived through convolution, resulting in different cases based on the value of t. As n approaches infinity, the expected outcome is that the solution converges to a form consistent with f(t) = δ(t - t₀). Participants express confusion about the behavior of terms as n increases and clarify that f(t) should be zero outside the defined interval. The conversation emphasizes understanding the transition from a finite to an infinite limit in the context of the Dirac delta function.
Summer95
Differential equation: ##Ay''+By'+Cy=f(t)## with ##y_{0}=y'_{0}=0##
Write the solution as a convolution (##a \neq b##). Let ##f(t)= n## for ##t_{0} < t < t_{0}+\frac{1}{n}##. Find y and then let ##n \rightarrow \infty##.
Then solve the differential equation with ##f(t)=\delta(t-t_{0})##.
Convolution (Boas)
Laplace Transforms (Boas)
So when I go through the first part with ##f(t)= n## for ##t_{0} < t < t_{0}+\frac{1}{n}## and do convolution I get ##y=\frac{1}{A(b-a)}\int_0^t(e^{-a(t-\tau)}-e^{-b(t-\tau)})f(\tau)d\tau## which has different cases depending on t:
0 if ##t<t_{0}##
##\frac{n}{A(b-a)}(\frac{1}{a}(1-e^{a(t_{0}-t)})-\frac{1}{b}(1-e^{b(t_{0}-t)}))## if ##t_{0}<t<t_{0}+\frac{1}{n}##
##\frac{n}{A(b-a)}(\frac{1}{a}(e^{-a(t-t_{0}-\frac{1}{n})}-e^{a(t_{0}-t)})-\frac{1}{b}(e^{-b(t-t_{0}-\frac{1}{n})}-e^{b(t_{0}-t)}))## if ##t>t_{0}+\frac{1}{n}##
I don't understand what happens as ##n\rightarrow \infty##. I know it should become
##\frac{1}{A(b-a)}(e^{a(t_{0}-t)}-e^{b(t_{0}-t)})## for ##t>t_{0}## because that is what I get when I use ##f(t)=\delta(t-t_{0})## from the beginning. But what happens to all the extra terms? And the n out front that goes to infinity?
Convolution (Boas)
0 if ##t<t_{0}##
Is ##f(t)## supposed to be zero for ##t < t_0## and ##t > t_0+\frac{1}{n}##?
Ray Vickson said:
Is f(t)f(t)f(t) supposed to be zero for t<t0t<t0t < t_0 and t>t0+1nt>t0+1nt > t_0+\frac{1}{n}?
Yes! Sorry I forgot to specify that.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 31 ·
