The existance of Electric field
The discussion revolves around the existence of induced electric fields in relation to a changing magnetic field, specifically focusing on a point labeled C within circular regions of varying radii. Participants explore the implications of Faraday's Law and the conditions under which electric fields may or may not exist at point C.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants examine the relationship between changing magnetic fields and induced electric fields, questioning the conditions under which electric fields exist at point C. Some express confusion over the calculations and definitions used, while others suggest that contributions to the electric field must be considered from all areas.
The discussion is ongoing, with participants providing insights and questioning each other's reasoning. Some have offered clarifications regarding the calculations and assumptions made, while others are still grappling with the implications of their findings.
There are indications of confusion regarding the definitions of the magnetic field and the spatial considerations of the problem. The validity of the calculations is also under scrutiny, particularly in relation to the application of Faraday's Law.
cuongbui1702
B is increasing with rate: dB/dt
when C is center of circle 1, Induced Electric Field is 0, but when i take another circle, in C, existing Induced Electric Field
I used this equation to prove
Do Induced Electric Fields exist in C??
Please show your working.
When the B field changes, there should be an accompanying electric field so that $$\nabla\times\vec E = -\frac{\partial \vec B}{\partial t}$$
If the loops you have drawn are conducting, then either of them should have an induced current.
what i mean is: in C, Existing of Induced Electric Fields
I have: E = (r/2).dB/dt( r is radius of circle 1)=> C doesn't have electric field
But when E' = (r'/2).dB/dt(r' is radius of circle 2) => C still have electric field( C belongs to circle2)
I think when B change, every where in space also have electric field, am i right
It is not always the case. The trouble is that your calculations make no sense.
You are trying to use Faradays Law:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/maxeq2.html#c3
I do not see how you have done your calculations.
I do not see how you got your conclusions.
i.e.
If r>0, and |dB/dt|>0 then E≠0 so why do you say this means that there is no electric field?
Also - how did you use the fact that both B and E are vectors?
I think you need to be more careful in your definitions ... do you intend that the B field is defined throughout all space?
You also need to go through the calculation one step at a time.
C have electric field, isn't it?
Oh I think I get you.
The calculation depends on where you put the center of the circle ...
But you've forgotten something - you are only calculating the contribution to the induced electric field due to the flux inside the circle.
In the first example you discovered that the flux at point C has no contribution to the field there.
In the second you found a non-zero contribution to the flux.
To get the total E field at C, you need to add the contributions from everywhere.
I don't think the calculation is actually valid for the B field you have in mind - but I can't tell for sure.
If the uniform magnetic field is confined to a circular region, then the induced E will be zero at the center, C, of the region. You should be able to convince yourself that there is no contradiction with applying the integral form of Faraday's law to any closed path. (Note that for a circular path not centered at C, then you will not be able to pull E out of the integral.)
If the uniform B field extends to infinity in all directions, then there is no unique answer to the induced E field distribution. So, it's not a well-defined problem.
A similar situation occurs if you imagine all of infinite space filled with a uniform charge density ρ and try to find the E field produced by ρ using Gauss' law. There will be an infinite number of different E field distributions that satisfy Gauss' law.
