The force necessary to bend a scaffold pole
  • Thread starter Thread starter Kevin Gutridge
    Bend Force Pole
The discussion centers on calculating the force necessary to bend a scaffold pole used in a barn structure. The barn features curved scaffold poles with a height of 20 ft and a width of 30 ft, spaced 7 ft apart. After removing a section of one pole, it bent approximately 1.5 mm under load. The torsional strength of the pole is noted to be around 5 kN, which is crucial for understanding the forces at play in this scenario.
  • Understanding of structural mechanics
  • Knowledge of torsional strength and shear resistance
  • Familiarity with scaffold pole specifications
  • Basic principles of force and bending in materials
  • Research how to calculate bending moments in structural elements
  • Learn about the properties of materials used in scaffolding
  • Explore methods for measuring force and deformation in structural components
  • Investigate the principles of torsion and shear in engineering applications
This discussion is beneficial for structural engineers, construction professionals, and physics students interested in the mechanics of materials and the design of load-bearing structures.
Kevin Gutridge
Hi, I have a question on the force necessary to bend a scaffold pole.
I have a barn made of curved scaffold poles approximately 20 ft high at the apex and 30 ft wide at the base, having a hemispherical cross section. These ribs are spaced approximately 7ft apart.
Along the sides of the structure are horizontal poles running the length of the structure, spaced approximately at 5ft intervals vertically. The structure is covered with corrugated iron sheets.
I have removed a section of pole from one rib between the ground and the first horizontal pole. The pole bent downwards approximately 1.5 mm.
I would like to calculate the force that is acting on the central pole causing the bending, this would give me an idea as to the weight acting on it.
I realize there are two main forces resisting the bending. The torsional strength of the pole and the shear résistance to the creation of the rhomboids from the previous squares. I have the torsional strength which is approximately 5 kN.
This would make a brilliant exam question in the UK for a physics exam, but I did mine in 1974.
Can someone help me as I can''t find my old school books...
Thanks in advance
Kevin (London, UK).
I'd try bending the pole you removed to see how much force is required.
It is not the same length and doesn't have the support of the structure above, very good simple solution though, may do it anyway. Thanks Mate.
Kevin
  • · Replies 20 ·
11K
  • · Replies 26 ·
27K
  • · Replies 26 ·
