pixel01
- 688
- 1
How can I calculate the force of a bullet shot against a wall if the velocity v and mass m are given?
The calculation of the force exerted by a bullet upon impact with a wall can be determined using the formula F = mv/t, where m represents the mass of the bullet, v is its initial velocity, and t is the time taken to come to rest. In scenarios where the bullet does not deform, the average force can also be calculated using the kinetic energy formula E = mv²/2 and the penetration distance s into the wall, resulting in F = E/s. The discussion emphasizes that additional factors, such as the wall's material properties and the bullet's deformation, significantly influence the force calculation.
PREREQUISITESPhysics students, engineers, and anyone interested in understanding the dynamics of projectile impacts and force calculations in collision scenarios.
pixel01 said:How can I calculate the force of a bullet shot against a wall if the velocity v and mass m are given?
berkeman said:Force = mass x acceleration, right? If the bullet doesn't deform as it stops, then you just need to graph the deceleration versus time, and that will net you the force versus time with a little math.
Is this homework? If so I should move it to Homework Help, Intro Physics.
I think you'll need more information that just the initial momentum (P). If you had the time (t) taken for the bullet to come to rest you could treat it as a simple 1-D collision:pixel01 said:How can I calculate the force of a bullet shot against a wall if the velocity v and mass m are given?
The mass and velocity only give you kinetic energy: E=m*v^2/2pixel01 said:How can I calculate the force of a bullet shot against a wall if the velocity v and mass m are given?
