Mapping D* onto a Triangle: Investigating One-to-One Functions
  • Thread starter Thread starter der.physika
    Geometry
The discussion focuses on the mapping T defined on D* = [0,1] x [0,1] as T(x*,y*) = (x*y*, x*). It is established that T is not one-to-one due to the inclusion of the origin (0,0), but it can be made one-to-one by excluding the point where x=0. Participants suggest breaking down D* into simpler functions to analyze the image set D. By using parametric equations, the vertices of the resulting triangle are identified, confirming the image set and the non-injective nature of T. The conversation concludes with validation of the findings regarding the mapping and its characteristics.
der.physika
Let D* = [0,1] x [0,1] and define T on D* by T(x*,y*) = (x*y*, x*). Determine the image set D. Is T one-to-one?
Okay... So I know it is not one to one, if you take out the point (x=0) then it is one-to-one, so you must be careful with the origin.
But I don't know how to find the image set D. Because there are two variables in the first component in T x and y*. How do I find D?
hi der.physika! :smile:
it's easier if you break D* into two functions
what is the image of the function that sends (x, y) to (x, xy)?
(it may help to consider all the (x, 1)s)
Okay... I think I found the solution
by using parametric equations
(t,0); (1,t); (t,1), (0,t) and plugging them in yields (0,0), (0,0), (t,t), (0,t) which makes it not 1 to 1. So... it gives me the triangle with those vertices. is this correct?
(just got up :zzz: …)
der.physika said:
… (t,0); (1,t); (t,1), (0,t) and plugging them in yields (0,0), (0,0), (t,t), (0,t) which makes it not 1 to 1. So... it gives me the triangle with those vertices. is this correct?
That's right! :smile:
(as you've seen, a short-cut that will work in any "non-folding" case is to simply find where all the corners go to :wink:)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 0 ·
