The Human Double Slit Experiment
Legaldose
Okay it's been well established that objects with momentum exhibit wave like properties. Hence, electrons being observed forming interference patterns when scattering off of crystal lattices. Also I recently read this webpage. At the bottom it mentions performing a double slit experiment with cats firing them haphazardly at two slits to see if they interfere. Now obviously it wouldn't work in any normal sense. But it mentions a lot of little technicalities, one obvious one for me is that the de Broglie wavelength of any object comparable to humans would be comparable to Planck's constant, so extremely tiny slits would be needed (correct me if I'm wrong). My question is what are those other "technicalities" mentioned. Also it says that you would need to space out the firing of the cats in a time interval longer than the age of the universe, I just plain don't understand that bit, why do you need to space out the firings for larger objects that much? I figured as long as you waited until one already hits, that would be good enough. Any clarification is welcomed.
Its the decoherence thing. For macro objects to show quantum behavior they need to be isolated from the environment which, to put it mildly, is VERY VERY hard to do eg it would need to be cooled to near absolute zero.
The spacing out thing may be that the slits would need to be so small it would take a huge amount of time for a cats wave-function to leak through - just a thought off the top of my head.
Thanks
Bill
Maybe the author is trying to say that:
The speed needs to be really slow, so as to reduce the momentum -- so that the wave-length is long enough?...for interference effects to show up.
I thought it was fairly clear that he meant the time in between firings.
Thanks for both of the answers, I'm starting to get it now. Or at least I think I am :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
