The James Webb Space Telescope
546 replies · 78K views
All spacecraft are expected to experience and designed to withstand micrometeoroid impacts, and JWST is no different. The observatory's engineers even subjected mirror samples to real impacts to understand how such events might affect the mission's science.
However, the recent impact was larger than those that mission personnel had modeled or could test on the ground, according to the statement.
from the link provided by @mfb
Astronomy news on Phys.org
165 days since launch, 33 days till first image I was just hoping the words meteor/micrometeoroid would not feature significantly on the thread before July 12th.
Better news, A few more signed off yesterday.
An early contender for observation time, the "Next Generation Deep Extragalactic Exploratory Public" will build on Hubble's deep field observations. The "P.I." is a Hubble Fellow with plenty of experience in Deep Field, high redshift work.
From the news release: https://webbtelescope.org/contents/news-releases/2022/news-2022-015.html
(“We’re using two science instruments at once, and they will observe continuously.” They will point Webb’s Near-Infrared Imager and Slitless Spectrograph (NIRISS) on the primary Hubble Ultra Deep Field, and Webb’s Near-Infrared Camera (NIRCam) on the parallel field, getting twice the bang for their “buck” of telescope time.)
Principal Investigator, Prof. S. Finkelstein
NGDEEP Proposal #2079 Cycle: 1, GO
https://www.stsci.edu/jwst/phase2-public/2079.pdf
An overview from the above pdf.
"We propose NGDEEP: The Webb Deep Extragalactic Exploratory Public Survey. NGDEEP leverages efficient parallel observations over 121.7 hr with NIRISS in the Hubble Ultra Deep Field (HUDF) and NIRCam in the HUDF-Par2 field to constrain the physical processes dominating feedback in galaxies from z~1-12. Observing with JWST in the HUDFs leverages off the deepest optical imaging from Hubble and makes NGDEEP a premier legacy field for both missions.
NGDEEP observes deeply with NIRISS (60-190 ks) to detect faint emission lines (~ 10^-18 cgs) for >1000 mostly low-mass (log M/Msol = 7-9) galaxies. NGDEEP-NIRISS will enable robust constraints on the low-mass end of the mass-metallicity relation and constrain stochastic star-formation by probing H-alpha based star-formation rates to 0.1 Msol/yr in these low-mass galaxies. These measurements will limit chemical enrichment and feedback physical prescriptions in models, which are currently unconstrained at these masses.
In parallel, NGDEEP will obtain the deepest 6-band NIRCam imaging (m~30.6-30.9) on the HUDF-Par2 field. NGDEEP-NIRCam will probe z > 12, and constrain stellar feedback prescriptions in models by precisely measuring the shape of the faint-end of the UV luminosity function at z~10. These data will provide unprecedented morphological detail in galaxies at all redshifts, and reconnoiter the sites of first black hole formation.
Being public immediately, NGDEEP follows in the footsteps of the Hubble deep field programs, enabling the community to explore the power of Webb when pushed to its limits. As a treasury program, we are committed to the rapid reduction and release of high-quality reduced data products and catalogs."
Filip Larsen said:
Almost there. It appears that we should be ready to become teary eyed on July 12th ...
https://arstechnica.com/science/202...dinary-images-captured-by-its-webb-telescope/
Yes Just two modes to sign off and If the NASA scientists are overcome with emotion at this stage then we should buckle in!
The “our beautiful universe” community will probably go nuts, be great some feedback from them on the 12th
pinball1970 said:
I wondered about the black hole Suns!
". In addition, the centers of bright stars appear black because they saturate Webb’s detectors, and the pointing of the telescope didn’t change over the exposures to capture the center from different pixels within the camera’s detectors"
Yeah, this is not an uncommon convention in astrophotography software (e.g., FITS viewers), particularly for use in quick-and-dirty viewing of the data. Saturated pixels are often displayed as black to let the astronomer know quickly (due to the inevitable high contrast) that saturation has occurred. It's not universal though -- it's just a convention -- and depends on the software. [It doesn't change the underlying data; rather it's just a matter of how the data is displayed.]
The same thing is often done on high-end terrestrial cameras too. So it's not limited to astronomy. Many high-end cameras (Nikon, Canon, etc.) will have a mode such that preview and display on the back of the camera will go black (or some predefined color [or pattern]) for regions where saturation occurs. It's a way of the camera telling the photographer, "Ah, hell. Looky-here, you've gone done blown the highlights again, you bastard."
A list of first image targets, compliments of NASA/JPL.
https://www.jpl.nasa.gov/news/nasa-shares-list-of-cosmic-targets-for-webb-telescopes-first-images?
Carina Nebula: The Carina Nebula is one of the largest and brightest nebulae in the sky, located approximately 7,600 light-years away in the southern constellation Carina. Nebulae are stellar nurseries where stars form. The Carina Nebula is home to many massive stars several times larger than the Sun.
WASP-96b (spectrum): WASP-96b is a giant planet outside our solar system, composed mainly of gas. The planet, located nearly 1,150 light-years from Earth, orbits its star every 3.4 days. It has about half the mass of Jupiter, and its discovery was announced in 2014.
Southern Ring Nebula: The Southern Ring, or “Eight-Burst” nebula, is a planetary nebula – an expanding cloud of gas surrounding a dying star. It is nearly half a light-year in diameter and is located approximately 2,000 light-years away from Earth.
Stephan’s Quintet: About 290 million light-years away, Stephan’s Quintet is located in the constellation Pegasus. It is notable for being the first compact galaxy group ever discovered in 1787. Four of the five galaxies within the quintet are locked in a cosmic dance of repeated close encounters.
SMACS 0723: Massive foreground galaxy clusters magnify and distort the light of objects behind them, permitting a deep field view into both the extremely distant and intrinsically faint galaxy populations.
  • Love
What's this thing tonight? With Joe Biden? They are releasing one image?
@mfb @collinsmark @Oldman too
I posted a screen grab today and did not even notice the Biden date. On Random thoughts.
I saw your screen grab, didn't notice the fine print about today though, thanks for pointing out the "reveal".
Yeah, what the heck does Biden have to do with a NASA release? And the news articles say it would happen at 5:30PM US Eastern Time, which was an hour ago and no images anywhere that I can find so far...
Thank you very much, Devin. Is the color scheme that you showed in the plot above in your post #285 a standard for coloring the IR images from Webb?
I'm completely puzzled. The statement, on the NASA web site, about the age of the galaxies in the image says
The image shows the galaxy cluster SMACS 0723 as it appeared 4.6 billion years ago.
Given that the Hubble has imaged galaxies at about 13.4 billion years old, what's the big deal w/ 4.6 billion years old? The Webb image does not appear to me to be any more clear than the Hubble Deep Field,
  • Skeptical
It looks like another metric/Imperial units conversion issue...
I think SMACS is a bit more in the foreground, magnifying galaxies behind it that are apparently deeper and sharper than the Hubble deep field images.
I saw this on the TV news this evening.
From: https://www.houstonchronicle.com/ne...ases-first-image-from-James-Webb-17297915.php
President Joe Biden released the first image from the James Webb Space Telescope on Monday, revealing what NASA called a "glimpse" into 13.5 billion years of cosmic history.
Typo substituting age of our sun for age of the universe?
Here's a side-by-side with a Hubble photo of the same cluster:
  • Love
It is about what's behind the cluster.
Be aware that the Webb pictures are in false color.
4.6 billion years is the age of the light that the telescope collected, based on the distance, hence "as it appeared ...".
The Ars technica story on this first image includes a link to the full image I haven't noticed in any of the other references mentioned (or I may simply have missed it):
https://stsci-opo.org/STScI-01G7JJADTH90FR98AKKJFKSS0B.png
