OCR
- 996
- 936
Yeah, I saw that....jim hardy said:Did anybody watch NOVA this week ? Some guy has solved the pyrotechnics problem with lithium batteries.
I have the seal of approval so I'll continue. The bare refrigeration units are available for self fitting into boats etc. and you can make the enclosure as thermally efficient as you like, unlike a ready made fridge. You can keep the mean consumption very low if you use thick enough insulation and use a 'chest' design with a thick lid. The biggest demand is when you put a new item in that's not already cold (or if you actually try to freeze down stuff). They're blissfully quiet runners, too and you can put the external condenser a good distance away from the unit. A bit on the pricey side but it does what it says on the tin.jim hardy said:Certainly that's good sensible advice.
old jim
1TB on a USB stick is available in my local shop. Where will it all end?Trainee Engineering said:flashdisk era where we can already store gigabytes worth of data
sophiecentaur said:1TB on a USB stick is available in my local shop. Where will it all end?
Not a good idea. The advances in information technology involved storing a fundamental unit of information (on/off) in ever smaller physical structures. Much of IT hardware engineering became exercises in managing complexity, i.e. how does one quickly carve 10 million transistors into a square mm, control all their interactions, and have them finally act as a useful macro level device. Energy storage has few if any parallels.Trainee Engineering said:... if we use the analogy of data storage, ...
Energy and data are not alike.Trainee Engineering said:I take it Tesla's Powerwall is currently the most advanced phase in energy storage tech? ...
so, if we use the analogy of data storage, we're still in floppy disk era where we can only store 1.44MB worth of data, ...
is this analogy describe current phase in energy storage technology?
is more in tune with steam power ca 1830Trainee Engineering said:yeah, I mean, we're still at 14kWh in 44 in × 29 in × 5.5 in package, so if I want to store 210 kWh, it will take 15 units which will take a lot of space.
I just learned Eos Energy is planning to sell their rechargeable zinc/air batteries to the consumer in 2017. I'm calling them tomorrow to see when I can get some. They have been selling them to utilities for a while now. Zinc is quite inexpensive, these batteries can be cycled over 5k (maybe 10k) times, they store 3 TIMES the energy of Li-ion batteries. Look at their website; they are many times superior. I think I'll buy Solar World solar panels. They are made in the USA and some of the most efficient ones there are. This year will be the year I go off grid. I will install this myself-I think installers might think they can rip u off. I will buy a transfer switch and get a certified electrician to install it. This will be so I will still be attached to the grid while makings sure everything is working OK. Transfer switches are not uncommon. They are for when someone has their own generator hooked up to their system.Trainee Engineering said:Hi all,
I'm interested in the latest development in battery technology. as of now, from what I understand, the most advanced tech in energy storage (battery) is created by Tesla, the PowerWall. but, even that, can only store 14kWh per unit. my house consumption is about 10kWh per day. my question is, what are the type of batteries out there available to the public? I'm only concerned of these things:
1. capacity --> I need to store 2-3 weeks worth of energy (in case of blackouts), so, it's somewhere around 140kWh - 210 kWh. if possible, I need it to be less than 10 units (so each unit is around 21kWh)
2. durability --> must be able to store huge amount of energy for a long period of time without dissipating. Now, it won't be charged and discharging frequently. charged only after a blackout, and won't be discharging until the next blackout, so storing for long time
3. warranty --> if possible, above 10 years warranty that energy leakage is less than 5%
price is not an issue. what are my options?
what's the latest type of battery suited for this type of usage?
thanks
One problem with metal air batteries has always been that their *power* density is dozens of times lower than a traditional electrolyte battery. Diffusing oxygen into the metal tends to happen at a much lower rate than ions diffuse in li-ion, especially when nitrogen and water vapor get in the way. So, it's long been possible to buy non rechargeable metal air batteries with greater *energy density* than li-ion, but to obtain the same power required infeasible parallel banks of metal air.discountbrain said:store 3 TIMES the energy of Li-ion batteries
