In short, I don't know if there is a clear answer to your question at this time.
Schreiberdk
http://arxiv.org/abs/hep-th/9710009" is still the standard explanation for why the BFSS conjecture should work.
BLG is something different, it was a hypothesis to describe M2-branes, that was subsumed by the later http://arxiv.org/abs/0806.1218" .
M(atrix) theory is about D0-branes, and a D0-brane is an M2-brane shrunk to a point, so there really ought to be a connection, but it's beyond me for now.
I think http://arxiv.org/abs/1003.2599" tried to look at this.
but I'm not so sure now. My naive conception of M(atrix) theory, pending a proper investigation, was as follows: It describes lots of D0-branes. D0-branes have strings between them. So it's really about M2-branes with other M2-branes stretched between them. The strings are M2-branes with one dimension lost, the D0-branes are M2-branes with two dimensions lost, and losing the dimensions has to do with (1) the switch from M-theory to Type IIA (2) working in the infinite momentum frame. But we are using noncommutative geometry, so "dimension" turns into "number of matrices".
edit: What everyone normally says is that D0-branes are "units of momentum" or "Kaluza-Klein modes" in the eleventh dimension. I can cite http://www.sukidog.com/jpierre/strings/mtheory.htm" to support my contention that the D0-brane is a shrunken M2-brane, but I can't seem to find direct support for this in the technical literature. So here's one way to think about the issue: Suppose we think of M-theory in terms of "branes plus supergravity". The question arises - are these d=11 KK modes excitations of space-time itself, or are they M2-branes moving around the d=11 circle, or is there no difference? A similar question arises for D6-branes, which in M-theory also correspond to a geometric configuration of the background space, rather than to an M-brane configuration.
D-branes are sources for strings, and strings are M2-branes, so whatever a D-brane is, M-theoretically, it has to be a source for M2-branes. But since a geometric configuration can have a potential energy, it can be such a source (think of pair production in curved space-time), so this reasoning doesn't resolve the issue.
Looking at section 3 of the paper cited by atyy, I'm not convinced that even the experts know how to think about this correctly:
1003.2599 said:
We saw that the BFSS model - a (0+1)-dimensional U(N) Matrix model on the worldvolume of N D0-branes - describes M-theory in discrete light cone quantization. However, since the D0−branes are momentum modes on the compact 11th dimension, this description of M-theory is not a fundamental one. Instead, as shown by Sen and Seiberg ..., it appears because of the equivalence of the original M-theory with a decoupled theory of D0-branes living in another M-theory. Any fundamental description of M-theory must involve M2-branes instead, but we don’t know how to formulate it.
"Another M-theory" refers to M-theory compactified on a (very small) space-like circle rather than on a light-like circle. M-theory compactified on a space-like circle is the form of M-theory that was originally discovered by Witten, when looking at the behavior of D0-branes in Type IIA string theory at strong coupling. Seiberg relates the lightlike and the spacelike compactifications through a Lorentz boost. He also takes some limits involving momentum and the Planck mass, and maps the sectors of M(atrix) theory onto the sectors of M-theory as derived from Type IIA.
http://physics.stackexchange.com/questions/6424/good-introductory-text-for-matrix-string-theory"
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
Thread 'LQG Legend Writes Paper Claiming GR Explains Dark Matter Phenomena'
A new group of investigators are attempting something similar to Deur's work, which seeks to explain dark matter phenomena with general relativity corrections to Newtonian gravity is systems like galaxies. Deur's most similar publication to this one along these lines was: One thing that makes this new paper notable is that the corresponding author is Giorgio Immirzi, the person after whom the somewhat mysterious Immirzi parameter of Loop Quantum Gravity is named. I will be reviewing the...
Many of us have heard of "twistors", arguably Roger Penrose's biggest contribution to theoretical physics. Twistor space is a space which maps nonlocally onto physical space-time; in particular, lightlike structures in space-time, like null lines and light cones, become much more "local" in twistor space. For various reasons, Penrose thought that twistor space was possibly a more fundamental arena for theoretical physics than space-time, and for many years he and a hardy band of mostly...
