Calculating Energy from Mass Using E=mc²
The discussion focuses on calculating energy using the equation E=mc², specifically addressing a homework problem involving the masses of deuterium and tritium. The user initially added the masses of 5.030151g and 5.011267g, resulting in a difference of 0.018884g. After clarifications regarding unit conversions, the user correctly converted grams to kilograms, resulting in 1.8884 * 10^-5 kg, and calculated the energy produced as E = 1.7 * 10^12 Joules using the speed of light (c = 3 * 10^8 m/s).
  • Understanding of E=mc² and its application in energy calculations
  • Knowledge of unit conversions, specifically from grams to kilograms
  • Familiarity with the speed of light as a constant (c = 3 * 10^8 m/s)
  • Basic grasp of scientific notation and its use in calculations
  • Study the concept of energy units, specifically Joules and their derivation
  • Learn about Avogadro's number and its significance in chemistry
  • Explore more complex applications of E=mc² in nuclear physics
  • Practice unit conversion techniques for mass and energy calculations
Students studying physics, particularly those tackling energy calculations, as well as educators looking for examples of unit conversion and application of E=mc² in real-world scenarios.
ElegantSir
I have the question with a diagram posted in the thumbnail to make things easier.
E = mc²
The homework only had a single example for a question like this so I am not 100% sure how to get the answer. So far I've added the 2 masses:
Then I subtracted them both 5.030151 – 5.011267 = 0.018884g
Here is where I am stuck. I know that from the example I need to do something like 1.8884 * 10^(input some number here) but I have no clue how to get the number that it should be to the power to. All I know is after this I need to multiply 1.8884 * 10 ^ (?) by 3.8 * 10 ^ 8 to calculate the total amount of energy produced using E = mc²
E = mc²
Why are you assuming that the masses of the elements reacting are not in grams?
I think you are assuming, based on the wording of the question, that only 1 atom of D and T react, but that need not be the case. Only the ratios of the reactants matter.
Also, units should be carefully scrutinized here. If you take c in m/s, what mass units must you use in order to calculate energy in joules?
Im not quite sure what you mean by all of that. I assume you mean I need to convert grams to a different unit of measurement but I am not sure what. Also what do you mean by
"I think you are assuming, based on the wording of the question, that only 1 atom of D and T react?"
Well, joules are the SI units of energy. Joules are also derived units. What is the definition of a joule?
https://en.wikipedia.org/wiki/Joule
It's obvious that 1 atom of deuterium does not have a mass of 2.014102 g, but a certain number of deuterium atoms does have this total mass. Ever heard of a fellow by the name of Avogadro?
https://en.wikipedia.org/wiki/Avogadro_constant
If you're going to study physics, you've got to study units and understand how units are useful in deciphering physics problems.
Ahh I see where I went wrong. The example
Ahh I see where I went wrong. The example questions like to use numbers like 1.9 * 10^-4 rather than use the actual whole number so I got confused.
I would need to convert grams to kilograms which would mean the number would now become: 1.8884 * 10^-5
Now I plug it into E = mc^2 and get:
E = 1.8884 * 10^-5 * (3 * 10^8)^2
E = 1.7 * 10 ^ 12 (rounded of course)
Im assuming this is the correct answer now?
Always include the units in your calculation results. That's a habit you should acquire now.
Ahh yes it would be in Joules...Thanks for the help!
  • · Replies 25 ·
  • · Replies 16 ·
