The Parity Operator: Find the average value of the parity.
latnoa
A particle of mass m moves in the potential energy V(x)= \frac{1}{2} mω2x2
. The ground-state wave function is
\psi0(x)=(\frac{a}{π})1/4e-ax2/2
and the first excited-state wave function is
\psi1(x)=(\frac{4a^3}{π})1/4e-ax2/2
where a = mω/\hbar
What is the average value of the parity for the state
ψ(x)=\frac{\sqrt{3}}{2}\psi0(x)+ \frac{1-i}{2\sqrt{2}}\psi1(x)
∏\psi(x)=\psi(-x)
∏\psiλ(x) = \psiλ(x)
First off I'm extremely confused on how to approach this to the point of where I don't know what I'm solving for so I'm someone can help me understand the problem and what it's asking me to do.
I just finished reading the parity operator section and all I understand was that ∏ inverts the coordinates of the wave function. I also got that ∏^2 is the identity vector which means that the eigenvalues have to be ±1 and that an even eigenfunction corresponds to 1 while an odd function corresponds to -1 and The eigenfunction of the parity operator form a complete set. That's it from the book but it shows no examples or anything remotely close to what this questions asks.
Am I trying to solve for ∏? Why are the ground state and first state included in this problem? Please help. Anything will be helpful.
where a = mω/\hbar
Your expression for ##\psi_1(x)## is incorrect. There should be a factor of x in there.
You're being asked to find ##\langle \psi | \hat{\Pi} | \psi \rangle ##.
Think about how you'd calculate the average energy ##\langle \psi | \hat{H} | \psi \rangle ## of the state. You're being asked to do the same sort of calculation except this time with the parity operator instead of the Hamiltonian.
Hint: The energy eigenstates of the harmonic oscillator are also parity eigenstates.
Use Expansion Coefficients
First off, ##\psi##0 and ##\psi##1 are eigenfunctions of \Psi. You can see their expansion coefficients given in the equation for \Psi, I will refer to these as cn
The average value of the parity, or <\Pi> will be Ʃ|cn|2an, where the a's are the eigenvalues of the given eigenfunctions.
To find the eigenvalues use \prod\psi = a\psi
This should simplify the problem quite a bit -- it's actually very straightforward if you approach it this way, and you don't have to deal with any messy integrals.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
