The Physics of Helium Purging NO Solutions
  • Thread starter Thread starter CentGentdub
    Helium Physics
CentGentdub
I am curious about the physics behind why helium is or is not a good gas to use purging other solutions. I am explicitly interested in its effects with NO.
I know that Helium has been used for purging aqueous solutions prior to high resolution spectroscopy.
But perhaps you have a different context in mind. So please tell us what the context is. And if you include a reference to support the assertion, that would be ideal.
well, what I am doing is using helium to purge oxygen out of a system I have developed to measure trace concentrations of Nitric Oxide so I can try to solve some of the mysteries associated with the compound. I have been searching to see if there is a Math/Physics model for the mixture of gaseous solutions. The reason is because i have cleared all the leaks of my machine as well as put it in a nitrogen atmosphere and for some reason when My sample makes it to the mass spec i seem to be losing about 87% of the original sample.
1) You're purging an aqueous solution prior to assay of NO or NOx; 2) you're (or not?) chromatographing the solution; 3) you're doing a mass spec of the solution, or of the gase stream during the purging process?
You're going to have to come up with a more detailed description of what you're doing --- asking people to guess what you're doing and tell you what problems might arise just ain't going to get anywhere.
I gave a brief overview. All I want to know is The physics behind using Helium Gas to purge another gas in a system. Any System. But I have decided just to create my own model and move on. Thanks anyways.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
