Undergrad The Plane in the Wind Puzzle: Does a Constant Wind Affect the Round Trip Time?
  • Thread starter Thread starter SchroedingersLion
    Plane Puzzle Wind
The discussion centers around a brainteaser involving a plane flying between two airports with and without wind. It concludes that a constant wind increases the total round trip time because the wind's effect on the plane's speed is unequal in both directions. Specifically, while the wind boosts the plane's speed from A to B, it slows it down more significantly on the return trip from B to A, leading to a longer overall time. The conversation also touches on the mechanics of the situation, with some participants expressing frustration over the complexity of the physics involved. Ultimately, the consensus is that the round trip time with wind is indeed longer than without it.
SchroedingersLion
Hi everyone.
I came across the following brainteaser:
A plane travels from airport A to airport B and then returns to A from B. There is no wind, both trips follow a straight line, and the plane flies at constant engine speed.
Suppose now that a constant wind is blowing from A to B. Will the required time for the round trip change or will it remain the same?
If you want to think about it first, don't scroll down.
Solution and my question:The given solution is that the round trip with wind takes longer. While the wind decreases the plane's speed on the way to A by the same amount as it increases its speed on the way to B, the retardation on the way to A lasts a greater amount of time than the boost on the way to B.
As an intuitive explanation, one is supposed to imagine the situation in which the wind speed is equal to the engine speed. Then the plane would be able to reach B twice as fast, but would not move from its place on the way back.
I try to write down some basic mechanics to show this, but I embarassingly failed.
I take "engine speed" to mean that the engine runs at a certain power ##P_0##. Let the distance be given by ##s## and the time taken for the trip ##t_0 = t_{A,0}+t_{B,0}=2t_{A,0}##. The power is related to the velocity by ##v_0=P_0 / F_0## with the force that needs to be overcome ##F_0##, so that the needed time can be expressed as $$t_0=2t_{A,0}=2 \frac{s_A}{v_0}=2\frac{s}{P_0}F_{0}.$$
Now, let the wind blow from A to B. Can't I just model it as a constant force ##F_w## applied in that direction?
Then, the force from A to B with wind is ##F_{A,w}=F_0 - F_w##, and the force from B to A ##F_{B,w}=F_0 + F_w##.
Then, applying the formula above, the required time will be
$$t_w = t_{A,w} + t_{B,w} = \frac {s} {P_0} (F_{A,w} + F_{B,w}) = \frac {s} {P_0} *2F_0 = t_0. $$
Where is my error? Needless to say, it is pretty frustrating to study physics for years, obtain an MSc., only to fail on petty brainteasers that are not even meant to require a physics education:cry:
I think you are over thinking it.
In the rest frame of the air the plane has the same speed ##v## in either direction, so if the wind speed is ##w## what's the speed relative to the ground in each direction?
Likes vanhees71 and SchroedingersLion
Doing the same thing with light instead of an airplane was the basis of the Michelson–Morley experiment which should have measured a greater round-trip time depending on the speed of the aether relative to the line connecting A and B. It didn't show this, which falsified the aether-wind kind of thinking that came from Newtonian physics.
The M-M experiment calculations show that it doesn't matter which way the wind was blowing, only the speed of it. So if A is say east of B, a west wind or a north wind will both add the same time to the duration of the round trip, and if the wind is as high as the airplane speed, the round trip cannot be done at all.
Likes SchroedingersLion
OK, one can assume that the plane's engine speed ##v## is always measured relatively to the medium.
In that case, with tailwind, one has ##t_1=\frac {s}{v+w}## and with headwind ##t_1=\frac{s}{v-w} ##.
Adding them, one sees that the resulting time is larger than the time without wind, i.e. ##\frac {2s}{v}##.
No need to talk about power or forces...So, I assume that in my original post, the two equations ##F_{A,w}=F_0-F_w ## and ##F_{B,w}=F_0 + F_w ## are rubbish then.
I don't know that it's rubbish, since you would formally use some sort of force balance equation (cruising speed is the point at which engine thrust equals drag) to show that the airspeed is what they mean by "engine speed". But then I don't immediately see what you'd do with power after that.
Thanks Ibix!
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 69 ·
16K
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 48 ·
