The possiblity of a solid planetary disk
The discussion centers on the theoretical existence of a solid planetary disk as a rigid aggregate, which has not been observed or postulated in scientific literature. Participants argue that such a structure would be gravitationally unstable and subject to erosion, leading to a more spherical shape over time. The conversation shifts to the dynamics of rotating bodies, with inquiries about the critical limits of eccentricity for stability and the behavior of fluid bodies under rotation. It is noted that while solid disks are unlikely, stable, oblate spheroids, like Saturn, can exist due to their rapid rotation and gravitational forces. Overall, the consensus is that while interesting to consider, a solid planetary disk is not feasible in nature.
Loren Booda
Has the existence of a planetary disk condensed as a rigid aggregate ever been postulated or observed?
Astronomy news on Phys.org
Not that I have ever heard of, until yesterday at 11:06 PM...:biggrin:
It would be hard to imagine any physical process creating such an object, because it is not gravitationally stable.
- Warren
Basically, you've got a planet that has *two extremely tall mountains* dropping off to two extremely deep valleys. However it got that way, any form of erosion will rapidly reduce it to a more spherical form.
I think you're expecting that, even as a disk, gravity will somehow be normal to the surface. It isn't. Gravity will point to the centre of mass.
[EDIT] correction: *one extremely tall, planet-spanning mountain range*
like saturn's rings?
They are moving fast enough to stay in orbit. If the planet spun fast enough to maintain itself against collapse, it would surely break apart - and become rings!:smile:
How can one express the critical limit of failure with respect to the eccentricity for a rotating rigid body?
OK, now this is a different ball of wax. You're talking about a body rotating so fast that it is being radically deformed. It will not be stable over long periods.
DaveC426913,
Actually, I was trying to make a comparison between various bodies of similar rigidity, mass and angular momentum, but different eccentricities. At what eccentricity do such bodies start breaking apart? This reminds me of the problem of a flywheel used for energy storage.
Thank you for helping me form my question.
If the body is rigid the eccentrivcity has to be zero by definition.
Accretion discs are composed of a myriad of particles each on their own orbit, with different orbital periods. Inner particles orbit more quickly, with a smaller period, than outer particles.
Inside the Roche limit of a planetary/stellar body anybody composed of normal material would disintegrate as tidal forces overwhelm its tensile strength.
Certainly a disc of individual particles could not accrete there.
You might imagine a contrived, and probably therefore necessarily artifical, solid disc around a very small body such as an asteroid where tidal forces would be weak but I doubt you will ever find one outside a SF story.
Garth
What is the maximum eccentricity of a stable, fluid oblate spheroid?
zero? Did you mean eccentricity or oblateness?
Garth
Garth,
Please address the question in regards to oblateness.
Loren Booda said:
Garth,
The galaxy is pretty oblate and a self gravitating body of dust (stars) and gas.
Garth
Could a fluid also form a stable, rotating, significantly oblate, self-gravitating spheroid?
The shape would depend on the fluid, its density, total mass of the body, speed of rotation, viscosity etc. but the answer is yes! The actual detail would be quite complicated to calculate.
Is this what you are looking for? http://arxiv.org/PS_cache/astro-ph/pdf/0609/0609756.pdf
Garth
That's what Saturn is, sans rings. Saturn is visibly oblate.
http://www.nasa.gov/worldbook/saturn_worldbook.html"
"The rapid rotation of Saturn causes the planet to bulge at its equator and flatten at its poles. The planet's diameter is 8,000 miles (13,000 kilometers) larger at the equator than between the poles. "
As Saturn is only 75,000 miles in diamter - that's more than 10% oblation.
Garth,
Yes, although I had not considered charge separation (mentioned at first in regards to MHD). From what I can tell, this method uses stochastics conventionally and hydrodynamic variables unconventionally.
Can anyone beat the entry of Saturn by DaveC426913 for an oblate fluid?
Didn't Maxwell say this was impossible?
