The Probability that N and E bridge hands have the same number of spades?
  • Context: High School
  • Thread starter Thread starter Entertainment Unit
    Bridge Probability
The discussion focuses on calculating the probability that two bridge hands, held by players N and E, have the same number of spades. The events are defined as A_i, where i represents the number of spades each player has, with calculations provided for i ranging from 0 to 6. The final probability is approximated to be about 18%, derived from the total number of ways to distribute spades and the remaining cards among the hands. The calculations utilize combinatorial methods and the Discrete Uniform Probability Law to arrive at the conclusion.
  • Understanding of combinatorial mathematics, specifically binomial coefficients.
  • Familiarity with probability theory and the Discrete Uniform Probability Law.
  • Knowledge of card games, particularly the rules and structure of bridge.
  • Ability to perform calculations involving factorials and combinations.
  • Study combinatorial probability in card games, focusing on bridge scenarios.
  • Learn about advanced counting techniques, including multinomial coefficients.
  • Explore the application of probability distributions in card games.
  • Investigate the general case of N cards in a deck and its implications for probability calculations.
Mathematicians, statisticians, and bridge enthusiasts looking to deepen their understanding of probability calculations in card games, particularly in scenarios involving combinatorial distributions.
Entertainment Unit
TL;DR
The question: suppose we deal four 13-card bridge hands from an ordinary 52-card deck. What is the probability that the North and East hands each have exactly the same number of spades?
I have an answer, but I can't find a solution anywhere to confirm it, and it's a little beyond my programming ability at the moment to do a brute force solution.
Is my answer correct? If not, where did I go wrong?
My answer is as follows:
Let ##S## be the set of all outcomes of dealing four labelled 13-card hands from a standard 52-card deck.
Let ##A## be event "N and E have exactly the same number of spades."
Let ##A_i## be event "N and E have exactly ##i## spades each."
Note that when ##i > 6##, ##\mathbb {P}(A_i) = 0## since there are only 13 spades in a standard deck of cards.
In the case of event ##A_0##, there are
  • ##2^{13}## ways to deal the 13 spades into hands S and W,
  • ##\binom {39} {13}## ways to "top up" hands S and W, and
  • ##\frac {26!}{13!13!}## ways to partition the remaining cards into hands N and E.
By the fundamental principle of counting, ##|A_0| = 2^{13} \binom {39}{13} \frac {26!}{13!13!}##.
In the case of event ##A_1##, there are
  • ##\binom {13}{2}## ways to assign 1 spade each to hands N and E,
  • ##\binom {50}{24}## ways to "top up" hands N and E, and
  • ##\frac {26!}{13!13!}## ways to partition the remaining cards into hands S and W.
By the fundamental principle of counting, ##|A_1| = \binom {13}{2} \binom {50}{24} \frac {26!}{13!13!}##.
By similar logic to that used to find the cardinality of event ##A_1##:
  • ##|A_2| = \binom {13}{4} \binom {48}{22} \frac {26!}{13!13!}##
  • ##|A_3| = \binom {13}{6} \binom {46}{20} \frac {26!}{13!13!}##
  • ##|A_4| = \binom {13}{8} \binom {44}{18} \frac {26!}{13!13!}##
  • ##|A_5| = \binom {13}{10} \binom {42}{16} \frac {26!}{13!13!}##
  • ##|A_6| = \binom {13}{12} \binom {40}{14} \frac {26!}{13!13!}##
Since the events ##A_i, i \in \{0,1,2,3,4,5,6\}## are disjoint,
##|A| = |\bigcup_{i \in \{0,1,2,3,4,5,6\}} A_i| = \sum_{i=0}^6 |A_i|##​
By the Discrete Uniform Probability Law,
##\mathbb {P}(A) =\frac {|A|}{|S|} = \frac {|A|}{\frac {52!}{13!13!13!13!}} = \frac {507696703}{31260638524067527680000}##​
Is this correct? If not, where did I go wrong?
Edit: updated answer, but it's still likely wrong.
##\mathbb {P}(A) =\frac {|A|}{|S|} = \frac {|A|}{\frac {52!}{13!13!13!13!}} = \frac {91957}{1508157204050}##​
That looks like a very small number. I make it about 18%.
In the case of event A0A0A_0, there are
  • 2132132^{13} ways to deal the 13 spades into hands S and W,
  • (3913)(3913)\binom {39} {13} ways to "top up" hands S and W, and
You only count, the number of ways 13 cards can be selected to "top up" S and W, but not the number of ways these can be divided between S and W.
Here's a rough estimate:
Let's say that North gets two, three or four spades with roughly equal probability of ##1/4##, leaving ##1/4## for everything else. And, assume that East gets the same independent of what North has.
That gives us an approximate probability of ##1/16## for North and East to have two spades each and the same for three spades each and four spades each. That's a total of ##3/16##. That's a first guess.
To calculate the number accurately, we take the six cases where E and N share zero to six spades.
The number of ways that N has ##n## spades is:
$$N(n)= \binom{13}{n}\binom{39}{13-n}$$
The total number of N hands is:
$$N = \binom{52}{13}$$
Then for East we have (given that N has ##n## spades):
$$E(n) = \binom{13-n}{n}\binom{26+n}{13-n}$$
And the total number of East hands is:
$$E = \binom{39}{13}$$
Then the probability that N and E both have ##n## spades is:
$$P(n) = \frac{N(n)}{N} \frac{E(n)}{E}$$
And you can sum the six resulting probabilities. The most likely, for example, is three spades each, which has a probability of about ##8 \%##. And the total probability is about ##18\%##, which is a bit less than the rough estimate above.
Thanks for the help! I finally got ##\frac {28035698399}{158753389900} \approx 0.177##.
I didn't solve the problem, but I would be inclined to attack it via the general case: 4N cards in a deck, and work it out by hand for N=1, 2 and maybe 3. Once I get it right for N, plug in N=13.
For example, I would not be trying to partition cards between S and W.
  • · Replies 25 ·
10K
12K
  • · Replies 100 ·
12K
