The problem of energy appearing out of nowhere
33 replies · 4K views
Dale said:
The question was if an alternative universe without that feature is self consistent. And it clearly is.
Is it? That's the question. The fact that you can write down a force equation with a damping term, so that mechanical energy is not conserved, does not prove that that equation is part of a self-consistent model. I haven't been able to find a non-paywalled version of the paper you referenced, so I can't look to see if it addresses this.
Very interesting discussion. I'd note that the arXiv preprint I referenced in a related thread (Hobson, Barker & Lasenby, arXiv:2605.19719), proving that no local gauge-invariant energy-momentum tensor exists for the linearised gravitational field, seems relevant here as well.
Of course it does. That is the whole point of writing the equations of motion and finding solutions. If you have a system of equations and that system of equations has a solution then it is self-consistent. It may be inconsistent with other models or principles, and it may be inconsistent with experiment, but it is self consistent.
Note that in non of my discussion w/Peter did either of us try to find the "energy momentum tensor of the gravitational field". We were always talking about the stress-energy-momentum tensor of the matter fields.
The SET of the "gravitational field" is subtle.
As a tensor, the SET must be well defined at every point and cannot be "transformed away" based on some coordinate transformation. However, the metric can be made to be ##\text{diag}(1,-1,-1,-1)## (depending on signature) at a point *and* the christoffel symbols made to be 0 *at a point* given some coordinates (see: Riemann Normal Coordinates).
So the dynamical parts of gravity is exhibited only "at the second derivative (curvature) level" -- this is a consequence of the equivalence principle.
It's hard to define a purely local object (SET) on a concept that you can locally "transform away".
In particular, note that ##\nabla_a T^{ab}=0## is a purely local conservation of energy of the matter fields and does not include the contributions from gravity. At a global scale you need a timelike KVF and asymptotic flat infinity to define something like the Komar mass which *does* include contributions from gravity.
But if the above condition on the SET is taken as a general "conservation of energy in GR" statement by practicing physics, I do not want to argue it. And I already conceded that point.
